Thread: RE: Water Feature Pump (how much HP do I need)?
    Jun 2014
    Jacksonville Beach
    44
    After some tweaks and changes my water feature compliment looks like it will be two 30 inch shear decent waterfalls (Pentair), two magicstream laminars, two bubblers and just maybe a firebowl with water feature (10-12 gpm), depending on what passes the Misses . Will a 2 HP whisperflow provide plenty of juice for this set-up? Thanks in advance for any experience/expertise.
    2015 Freeform shotcrete pool build in FL. RE: New Builder Build in FL, advice/comments please!!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Water Feature Pump (how much HP do I need)?
    I don't know the specific flow requirements for each item, but it should be provided on the documentation. Check your pump curves for the whisperflow. Hopefully the local pump expert will chime in.
