Thread: Intex AGP and pucks.
    West Michigan
    108
    I know that by using pucks all year the CYA builds up and you can never get ahead of the algee. That was the first year we had the 6000g frame pool. Last year I used stabilzer in a sock and then added bleach. This year I'd like to start out with the pucks and stop when I get enough stabilizer in. I'm going to try and drop my ALk down from the 200 it has started with too. So the question is... How many pucks can I use in a raw pool to get the stablizer at a good level before I just use bleach? The pool is about 6000 g's. Is there an easy chart someplace that I have missed? Thanks. Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    You may not get enough flow from your pump to chlorinate with pucks, especially in a floater. They just can't keep up with what the sun consumes. With a seasonal pool, there's no problem with using stabilized chlorine, but you may not be able to get enough of it in the water.
    For a 6000 gallon pool it takes 2 3/4 lbs of trichlor to bring the CYA level up by 30. That is about six 3" pucks.
    West Michigan
    108
    Thanks Jason, I knew there had to be an easy way to get started. One summer before BBB my cya got very high from just using the pucks and I had a green pool the second half of the very short Michigan swim season. I've used only a few pices of a broken puck so far. When I get to my 6th I'll test for the cya level. In the mean time I'm testing and so far my water and numbers are great. Thanks..Kimrst
