Results 1 to 7 of 7
Thread: Big differences between test kits. Confused
    Jul 2015
    Zeeland MI
    18
    Unhappy Big differences between test kits. Confused
    Before I joined this forum I ordered a drip test kit from Amazon Poolmaster 22270. It seems to have really good reviews and the results are pretty easy to read. However, I have 3 different dip kits and results from tests at Pools Plus that all seem to disagree with each other when testing PH and FC. Can anyone explain why I am seeing such a big difference?
    Poolmaster Kit Dip Strips Pools Plus
    PH 7.2 around 7.2 7.6
    FC 2 ppm around 5 ppm 6 ppm
    Other Levels
    ALK 120
    CYA around 30 (dip test)
    Which ones should I trust and why the big difference?
    15'x30' 54" deep Above Ground (Built July 2015)
    12,000 Gallons
    Ecco 22" Sand Filter
    Waterway 1.5HP pump model: SD-15-1N11CC
    Taylor k-2006 test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Big differences between test kits. Confused
    Trust none of the above. This is why we only recommend either the TFTestkits TF-100 or the Taylor K-2006 test kits. See Test Kits Compared. The FAS-DPD chlorine test is by far more reliable, accurate, and consistent even than DPD tests and test strips, but the test you are looking at in the 22270 is an OTO chlorine test and that can be hard to read/interpret unless you are used to it. Furthermore, the pH test in the TF-100 and K-2006 use special chlorine neutralizers that will not affect the pH so the pH will be accurate up to at least 10 ppm FC.
    Jun 2014
    14,980
    Chem Geek speaks the truth. I have the TF-100 and absolutely love it and the accuracy I receive. I also have the speed stir for easy mixing and it's perfect. One of those products that makes you wonder how you ever managed to go so long without it before. Seriously consider it if possible at TFTestkits.net.
    Jul 2015
    Zeeland MI
    18
    Ok. I got a new kit on order.
    I just shocked the pool for the heck of it with a pack of cal hypo that came with the pool. Dip strips showed a difference but the pool master drip kit show absolutely no change. Still showing 2 ppm. I Wonder why the kit got such good reviews.
    Mar 2007
    San Rafael, CA USA
    12,082
    Because no one knows any better. They don't do tests like you are doing and don't have any absolute good reference to compare to. Also, it's possible that you got a bum kit worse than others for some reason. Maybe it was exposed to too much light or heat in storage or shipping.
    Jul 2015
    Zeeland MI
    18
    Got my Taylor K-2006 kit today. I am pretty amazed at how easy it is to decipher the results.
    FC: 3.6 CC: 0 PH: 7.4 TA: 130 CH: 150 CYA: 35
    Not bad so far huh? Maybe bump up my PH to 7.6 and FC to about 4? In any case it amazes me how far off the PH reading was from the pool store. 7.4 was AFTER 1 box of Borax. When they tested it was probably at about 7.2 and they said 7.6.
    12,000 Gallons
    Jan 2014
    Buckeye AZ
    807
    Just play in the pool and the pH will come up. It's pretty much perfect.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
