Results 1 to 8 of 8
Thread: Liner Fade
    Orlando, FL
    690
    Liner Fade
    My pool liner is just over a year old and it has faded from the waterline to the seam at the bottom. Above the watering is as dark as the day I got it and the bottom too. I do not care as long as I get a few years. Initially, I thought the chlorine caused this but if that were the case, the bottom would be faded too. I wonder if it is due to some defect in the manufacturing process.
    C360_2015-07-20-17-27-18-242_zpspamqr7tn.jpg Photo by f3justusc | Photobucket
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Liner Fade
    Strange that the bottom is OK if it's the same original color so you are probably right that this is a manufacturing defect where the side vinyl does not have colorfast dye. It's either diluting in water or getting oxidized by chlorine, but much faster than it is supposed to. Note in this link that medium blue vinyl color is the most sensitive, probably because it uses an organic dye rather than inorganic dyes/chemicals for color.
    If you have some spare side vinyl you can soak some in water and another piece in chlorinated water (that you'd need to maintain as chlorinated) to see which causes the problem.
    Casey's Avatar
    SW PA
    10,438
    Re: Liner Fade
    Oh wow. it is really faded.
    Orlando, FL
    690
    Re: Liner Fade
    Quote Originally Posted by Casey View Post
    Yesterday is when it struck me how faded it is and how consistent the fading is. I cannot be bothered to worry about this so, I am going to put in the "ignore" pile.
    Casey's Avatar
    SW PA
    10,438
    Re: Liner Fade
    As long as it's not leaking, I'd do the same.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Liner Fade
    Is it brittle at all, or just faded?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Liner Fade
    Mine was fading evenly until this year. Now the waterline on the sunny side of the pool is much more faded than the rest. Consequentially, that was also where the tab floater would get stuck and hang out all day back when I still used one.
    Love TFP? Become a
    TFP Supporter!
    Orlando, FL
    690
    Re: Liner Fade
    Quote Originally Posted by PAGirl View Post
    It seems to just be fading.
