How to clean SWCG?
Usually the owners manual gives the cleaning procedure. Basically you remove the cell and then add a dilute acid to it to remove calcium scale.
Some cell manufacturers want you to use dilute muriaric (Pentair IC calls for 5:1 water:MA) while other manufacturers I've seen call for white vinegar (acetic acid). You have to check your owners manual to see what it says.
