Thread: How to clean SWCG?
    Jun 2010
    Toronto, ON. Canada
    230
    How to clean SWCG?
    Hi!
    MY SWCG is flashing lights for cleaning.
    What is the way to clean it DIY?
    It is 2 years old. I opened and looked inside and it looks pretty clean...
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    JoyfulNoise's Avatar
    May 2015
    13,192
    How to clean SWCG?
    Usually the owners manual gives the cleaning procedure. Basically you remove the cell and then add a dilute acid to it to remove calcium scale.
    Some cell manufacturers want you to use dilute muriaric (Pentair IC calls for 5:1 water:MA) while other manufacturers I've seen call for white vinegar (acetic acid). You have to check your owners manual to see what it says.
    Matt
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: How to clean SWCG?
    Do you have the manual? Or perhaps look online for the manual ? Most folks use a dilute MA solution, but that's the extent of my knowledge. Sorry!
