Results 1 to 7 of 7
Thread: Swim during SLAM?
    kne's Avatar
    Jun 2015
    Concord, CA
    133
    Swim during SLAM?
    Is there a way to do a slam while being able to swim during the day? I would call my pool dull, but clear. cc was .7 on Sunday afternoon.
    Probably could use a SLAM, If I could have my cake and eat it too, that would be great!
    18' x 48" Intex Ultra Frame AGP, ~6,500 gal
    Standard cartridge filter and SWG that came with the pool (soon to change!)
    Test kit will all the required juices and powders plus the stir monster
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Swim during SLAM?
    Any FC below the shock level on the CYA/Chlorine chart is safe to swim. It may accelerate fading of suits and be harder on hair than maintenance levels, but it's safe as long as you can see the bottom clearly and the surfaces aren't slippery. Test your FC and if it's below shock level, then you can swim. Bring it back up after the swim. Rinsing suits and bodies after the swim are a good idea.
    Isolated Spa - 345 Gallons
    Jul 2014
    kamloops bc
    39
    while on the shock topic, what is non chlorine shock?? what are the down sides of using it besides cost??
    14 x 28 IG, Hayward sand filter, Hayward 3/4hp pump, auto puck chlorinater,(used only when away) Hayward Natural gas heater, vinyl liner
    Feb 2014
    Central Minnesota
    5,080
    Non-chlorine shock is usually monopersulfate (MPS). It is a perfectly good oxidizer like chlorine but it tends to be more expensive. When you use it, it also shows up as CC when doing the FAS-DPD chlorine test as a false positive. It interferes with the reagents but MPS will also dissipate in several days. Maintaining adequate chlorine levels is enough to maintain a pool so it's more about keeping things less complicated and less expensive.
    May 2015
    Waterloo, Ontario
    51
    I just did a SLAM this past week with FC in the 25+ range and we swam all weekend...no problems here. Drys your skin out a bit more but that's about it.
    1999, 18x36 29k Gal, IG Vinyl, Sta-Rite Intellipro VS, Pentair SD80 Sand Filter, Pentair Millivolt 250m NG Heater
    2007, Hydropool H625 Platinum, 3HP/4HP pumps, Balboa Spa pack, Poly Planar Stereo c/w pop up speakers
    Mar 2007
    San Rafael, CA USA
    12,082
    The active chlorine level at SLAM level is 10 times higher than at the minimum FC/CYA levels in the Chlorine / CYA Chart in the Pool School. So one day of swimming at SLAM levels is equivalent in its effects to 10 days of swimming at normal levels. Technically it is equivalent to being in a pool with 0.6 ppm FC and no CYA so is less than many commercial/public pools that use no CYA and have at least 1 ppm FC such as many indoor pools. It most definitely oxidizes swimsuits, skin, and hair faster as my wife experienced every winter when swimming at a local community center pool where her swimsuits would degrade (elasticity got shot) every winter season while the same kinds of suits in our own pool over the summer lasted 7 years. The differences on skin and hair were noticeable as well though she would shower afterwards and use dechlorinating shampoo.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    We did a swim-n-slam for a week and a half a few weeks ago. CYA 70, FC 25-28. Worked out great. We only glow at night!
