Results 1 to 7 of 7
Thread: Polaris 360 moving but not vacumming
    Jul 2015
    Conroe texas
    1
    Hello, I am a new pool owner and our polaris pool cleaner recently stopped sucking up debris. I cleaned the filter in the hose. It still moves around the pool and the tails moves but it is not sucking anything up. Any suggestions?
    Casey's Avatar
    SW PA
    10,438
    Re: Polaris 360 moving but not vacumming
    Welcome to TFP.
    Someone should be around to help you. I would but I don't have an auto cleaner.
    Dec 2013
    PA. USA
    28
    Try holding it out of water, and see if the small jets are shooting water into the bag.
    Jun 2015
    Wildomar, California
    423
    Check that the throat doesn't have something in it. And check the jets throwing up the water.
    Aug 2015
    Torrance, CA
    3
    Just had the same problem with my 380. Remove the bag and look down the throat at the jets. Mine had little pieces of plastic debris stuck in the jets. I tried using a long piece of wire to try and dislodge the debris but after multiple failed attempts, ended up disassembling and cleaning.
    FYI you may want to check your in-line filter. I checked mine and lo & behold it was missing altogether... Bought replacement for $10
    Jun 2017
    Godley
    2
    Hello I'm having the exact same problem. Were you ever able to solve the problem? If so please share thank you
    Mar 2013
    Shawnee OK
    26
    Quote Originally Posted by boodles View Post
    Rose this thread from the dead. The 360 and 380 are very simple machines. They use water jets point UP from the bottom of the cleaner. This creates a suction effect. If you run the cleaner and pull it from the water, you should see those 3 jets spraying up the center. If they are not, then the nozzles are clogged. Time to take it apart and clean them out. You should also ensure that your filters are in place. I have an inline filter in addition to the filter at the wall fitting. This was before I moved to hair nets in my skimmer basket- that has been the biggest, cheapest solution for cleaning so far in my 6 years of pool learning.
    20k gal vollyball pool, IG, Vinyl, Sand filter, 1hp Pentair Superflo Dual Speed main pump 340042 (2016), 3/4hp Polaris PB4-60 booster pump (2015), Polaris 380 cleaner & Hasa Liquidator w/3/8" upgrade (2013).
    Pool approx 10 years old, liner at least 4 years old.
