Thread: Sand in deep end
    Jul 2015
    Reedsville pa
    1
    Post Sand in deep end
    I have about 15 pounds of sand in the deep end of my pool is there a way to get it out without using the filter system of the pool would may be a shop vac work
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,599
    Re: Sand in deep end
    First of all........you have to tell us how it got there! Welcome to the forum.
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    I doubt a shop vac will be of much use as the canister will fill too quickly and the float will shut off suction. I thnk your best best short of vacuuming to either waste or filter would be a stand alone pool vac like the Blaster or similar. You'll have to empty often and be patient but it will work. You might try "sweeping" or scooping some of the sand up first.
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
