Thread: Post Construction Issue
    Jul 2015
    Chevy Chase, Maryland
    2
    Just completed a complete renovation on a 50 year old plaster pool. We have completed the break in period and have the water in pretty good shape but still need to fine tune a bit. The problem is the kids are getting tiny cuts on their feet when playing pool basket ball. The surface feels smooth so I dont know what is causing the issue. I believe the plaster dust is all but gone and we are not using any gritty chemicals. Any thoughts?
    36K IG plaster pool 1962/2015, 1.5HP 2 speed whisperflow pump, DEV60 FIlter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Post Construction Issue
    Welcome to TFP!
    I would think a new, well finished plaster should be much smoother than that. Did they do any special startup, like an acid or "hot startup"? Just curious, but I would also suggest studying it closely at night and see if you can see any roughness in the surface from the application process. What is the installer saying about this?
    Essential Links:
    Apr 2013
    Sacramento, CA
    2,769
    Is the surface plaster or something else? Like Patrick said what does the surface look like at night with the lights on?
    When you get in the pool and run your hand over it does it feel rough?
    Did they do a "hot start" or "acid wash"?
    Jul 2015
    2
    Thanks for responding. The problem appears to be minimal now and I belive it may have been due to the curing process creating so much plaster dust. I will let you know should it flare up again.
    Thanks
