Results 1 to 11 of 11
Thread: Save money! Using Calcium Hypochlorite Without Raising Calcium Levels
    Jul 2015
    Spring Branch, TX
    1
    Hey guys, I've never posted here, but figured I would share what I've done for years as a way of adding chlorine cheaply...and without adding calcium -
    Basically:
    • I mix X-amount of desired calcium hypochlorite in a 5 gallon bucket (with water, almost to top), then secure with lid and put in shaded area.
    • Let sit for 24hrs.
      • Calcium & chlorine essentially separate into white chalky liquid on the bottom and liquid chlorine on top
    • The next evening, I siphon off the top portion (90%+ of top liquid) into another bucket and pour into deep end of pool.
      • IMPORTANT! Do not move the bucket at all once separated as it will re-mix depending on how much you move it.
      • (the siphoned liquid is a fairly clear, almost completely yellow, highly concentrated liquid chlorine)
    • Discard the leftover calcium at the bottom of the original bucket on whatever neighbors' plants you do not like
      • kidding
      • or maybe I'm not
    I have cost compared using various chlorinating methods and this seems to be the most cost effective way of chlorinating my pool. It takes a little time, but if you're frugal like me...it's worth the extra time.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Save money! Using Calcium Hypochlorite Without Raising Calcium Levels
    Cheaper than just straight bleach to begin with?-------without all the hassle?
    <<<<<<sends up the chemgeek "Bat" signal on this one!
    Jun 2013
    Texas City, TX
    25
    I would be willing to try. Thanks! Using bleach STILL has me chasing a rising pH. Thus muriatic acid costs. Then, baking soda cost. Maybe liquid chlorine use would not raise the pH the way OTC bleach does. I've read all those posts that bleach really doesn't raise pH. I beg to differ.
    18+K gal, IG diamond brite, 60 sqft DE Filter, Pentair intelliflo VS pump
    Attached spa + Pentair Mastertemp heater 400,000 BTU
    Built 1989, re-plastered early 2000s; new equip 2015
    Operator Proficiency: 1 year BBB follower
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Quote Originally Posted by quincy915 View Post
    For people using pucks or dichlor the switch to bleach seems like the bleach causes the pH to raise. But what's really happening is that the pucks and dichlor are acidic and they reduce pH so that the normal pH change of the pool is not as noticeable. In other words, the bleach is not raising the pH, the previous method of chlorinating was reducing pH.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Bleach does temporarily raise pH when first added but as the hypochlorite is consumed, the pH comes down again to the level it was at when the bleach was added. Bleach addition is a pH neutral process over the life of the bleach. Liquid chlorine is bleach. They are the same. One is labeled and sold as liquid chlorine or liquid shock but the only difference is the hypochlorite concentration. Exact same chemicals.
    You're saying you're fighting pH rise with muriatic acid then adding baking soda. What pH range are you maintaining? Why are you raising TA with baking soda? What TA levels are you seeing and targeting when you add baking soda?
    Isolated Spa - 345 Gallons
    Jan 2012
    'burbs of Augusta, Georgia
    7,299
    I'm sorry, but my time and the esthetics of not having random buckets sitting around is worth more to me than a few cents although I'm truly curious if a)this really works b) it really saves money
    Mar 2007
    San Rafael, CA USA
    12,082
    You say you use baking soda, but that means you probably have your TA set too high and that is the source of rising pH in the pool due to carbon dioxide outgassing. Pools are intentionally over-carbonated, but if you have too high a TA and too low a pH target, then the outgassing is faster and the pH rises. The pH would rise in your pool even if you were to use no chlorine at all. The pH rise from bleach is negligible unless you are using a poor-quality bleach with a lot of excess lye in it.
    According to this post your TA is at 70 ppm so that's not terribly high, but you should not add baking soda to raise it any higher from there. Do you have aeration sources such as a waterfall, spillover, fountain, etc.? Also, what is the age of your plaster (i.e. is it relatively new)?
    Jan 2014
    Buckeye AZ
    807
    what is the actual FC concentration of the liquid you are adding? and what is that volume? If you are trying to maintain a proper daily level of FC you'd have to have a pretty good handle on those numbers.
    I'd also think that super concentrated liquid chlorine is not safe to just dump in the pool without exposing liners or other components to too-high CH levels. And since it's a high concentrate, are you adding this every day, or doing enough to raise your FC to a level which will slowly come back down to your target over the next couple days? I'm curious to get the numbers behind it all.
    Plus, since you're doing this outside, that high concentration CH is going to degrade quickly once it's dissolved from the Calcium. Even 24 hours might be enough to reduce it quite a bit.
    Quote Originally Posted by kluke409 View Post
    Basically:
      • kidding
      • or maybe I'm not
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Mar 2007
    San Rafael, CA USA
    12,082
    Basically:
      • kidding
      • or maybe I'm not
    The solubility of calcium hypochlorite in distilled water is 214 grams/liter (see this link). So in a 5 gallon bucket you could only dissolve 4.05 kg or 8.9 pounds of Cal-Hypo. So how much Cal-Hypo are you adding to your 5 gallon bucket? If more (accounting for % Cal-Hypo in the product), then the excess will precipitate as calcium hypochlorite so you would be leaving chlorine back.
    Calcium hydroxide has limited solubility of 1.59 grams/liter (see this link) or a solubility product of 5.02x10-6 (see this link). A saturated solution of calcium hypochlorite would have a pH of around 11.7 so could settle out some calcium hydroxide. The saturated calcium hypochlorite solution has roughly 1M so this implies a maximum hydroxide concentration of sqrt(5.02x10-6/1) = 0.002 M or a pH of 11.4. So this is a very small amount of calcium removal.
    To get more calcium to precipitate, one would need to add either sodium hydroxide (lye) to precipitate more calcium hydroxide or sodium carbonate (washing soda) to precipitate out calcium carbonate. This would in effect substitute calcium for sodium but at extra cost for these additional chemicals.
    The separation of the calcium and chlorine doesn't make sense without adding something additional to, for example, precipitate calcium carbonate. If you were to use tap water then you would likely precipitate out some calcium carbonate and therefore remove some calcium that way, but if your tap water only had 80 ppm TA then the amount of calcium carbonate precipitated in 5 gallons would be only 1.5 grams of calcium carbonate. Now if you were to add sodium carbonate to this mixture, you could precipitate out the calcium as calcium carbonate and have sodium hypochlorite left in solution at around 13.8% Trade.
    However, without the addition of carbonate or hydroxide (or something to precipitate calcium), I don't see how the calcium can "separate". Calcium is a positive ion so for it to separate into its own layer even if it didn't precipitate it would need negative ions to go along with it and there aren't any in significant quantity other than hypochlorite.
    Of course, anyone here on this forum can simply try adding Cal-Hypo to a bucket of water below the level of saturation (i.e. below 1.8 pounds calcium hypochlorite per gallon factoring in concentration of Cal-Hypo) and see what settles after 24 hours and then take the water above what settles, add it to some larger volume of water, and measure any CH increase compared to the FC increase to see if enough calcium was really removed to make this practical.
    Donldson's Avatar
    NW Ohio
    2,888
    Assuming complete transfer of chlorine from the calcium to the water a 1 lb bag will raise the FC in 10,000 gallons by 7.7 ppm. A gallon of 10% chlorine will raise the FC by 10 ppm. In my area a bag of 68% cal-hypo costs at least $2.50 and a gallon of 10% Na-hypo costs $3.00. That makes 32 cents / 1 ppm / 10,000 gallons for cal-hypo and 30 cents per 10%. Can't speak for Texas prices but here it would literally cost more for the hassle of doing this.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Sep 2013
    Connecticut
    728
    Edited - deleted my earlier comment - thread has been split apparently.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
