Thread: Return jets blowing air
    Jun 2014
    Downingtown, PA
    1
    So I've noticed on my pool the return jets are blowing a lot of air.
    Yesterday, I looked at the pipe coming into the filter and the 90 degree elbow is cracked:
    I'm assuming I need to just replace this section of pipe correct? Looks like it's 2" pipe? It's an old Apollo DE-52 filter I believe. Anthony Pool Brass Multiport valve.
    Erik
    Jun 2014
    15,008
    Re: Return jets blowing air
    That would probably be best (replacement). Some folks may try an epoxy product to get-by for a while, but ideally replacement would be the ultimate solution.
    Jun 2015
    Wildomar, California
    423
    Ditto Texas. Replumb it. It's a permanent fix and I would not be surprised if the male fitting was loose also.
