Results 1 to 7 of 7
Thread: What shock product?
    Jun 2015
    spring hill fl
    22
    What shock product?
    FC is a 6.5
    CC is .4
    PH is 7.6
    CH is 200
    CYA 35 (lots of rain)
    TA 100
    temp 90
    im looking to lower the CC to 0
    13,500 gallon in-ground Salt water pool
    exposed aggregate pool finish
    pentair IC40
    pentair VS pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: What shock product?
    CC of 0.5 or less is acceptable but if you want to try to drive it down, bring your FC up to 10 ppm using bleach to see if that eliminates the CC. Liquid shock/bleach will only raise your FC. Your CYA is very low for Florida and a salt water chlorine generator. Have you considered raising your CYA level to help reduce chlorine loss to sunlight?
    Isolated Spa - 345 Gallons
    Jun 2015
    spring hill fl
    22
    my first time testing the CYA. i was surprised at the result. before i had water tested at pool store. the results were around 70. think its possible to loose that much to a weeks worth of rain?
    pentair IC40
    pentair VS pump
    30,431
    Lowering your CC's to zero is a waste of time. ,5 ppm CC's or less is treated as zero for our purposes.
    Not sure about the dilution on CYA but I am darn sure the pool store can be wrong by that much.....happens constantly.
    Feb 2014
    Central Minnesota
    5,080
    No. I do not. Reducing of 50% of your CYA would require replacing 50% of your water WITHOUT any mixing. If it was rain, you were very slightly diluting the CYA, then draining some off by backwashing. Pool stores are typically very bad at testing for CYA. Your result I would trust. To get more comfortable with your own test, make sure that you fill the tube and observe the result. Then pour the solution back into the dispenser bottle and fill the tube again. See if your observing a consistent number. You can do this multiple times with the same sample. It's also important to perform the test in full sun, with the sun behind you, holding the tube at about waist height, looking down into the tube.
    Jun 2015
    spring hill fl
    22
    sounds good. i will leave the cc where it is.
    i will also retest the CYA in a few days and post the result
    pentair IC40
    pentair VS pump
    Jan 2014
    Buckeye AZ
    807
    I think it's probably reasonable to give your pool an extra bit of FC before/after rain storms. Lots of folks recently are maintaining fine til a storm starts a bloom. I shoot for a target 2 or 3 ppm higher than normal the night before a storm is rolling in.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
