Thread: Borax or Boric Acid
    Apr 2014
    Lumberton,nc
    20
    Borax or Boric Acid
    I think its probably about time I add borates to my pool. Question is am I better using borax or boric acid for salt water pool?
    23k,IG vinyl,vs Hayward pump,sand filter,SWG, built 4/14
    Jun 2014
    15,298
    Re: Borax or Boric Acid
    Well, please keep in mind the difference of the two products. You may wish to read these two pages to help clarify:
    Borates - Why and How
    Have a nice day!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    I used boric acid since I didn't want to mess with MA. Funny 'cuz I use MA twice a month to lower my pH rise due to aireation. Lots of folks use DudaDiesel for their chemicals. I just went to the Dollar General and bought Roach/Ant killer. Not sure if that was the best way to go but it works for me.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    JoyfulNoise's Avatar
    May 2015
    13,262
    Salt water has nothing to do with it. Either method works fine; it's a matter of what is convenient and cheapest for you.
    So, what you should do is use PoolMath to figure out how much Borax/MA or Boric Acid you will need to raise your pool water from 0 to 50ppm. Then, you can compare the costs for each procedure. In my pool, ordering from Duda Energy (they are no longer called Duda Diesel) online and using boric acid was about $10 cheaper than using Borax (purchased from Walmart) and MA.
    Also, you'll want to follow the procedure as outlined in the link in the previous post. The key is to get your pH and TA adjusted to the point where you'd like it to be and then add the borates. If you choose to go the Borax/MA route, then the additions of the chemicals need to be broken up into 2 or 3 batches with a good deal of brushing and agitation in between. If you use boric acid, you can add it to the water all at once by broadcasting it around the pool and then brushing to mix it in.
    If you order boric acid, make sure you order the granular product not the fine powdered form. The fine powder will blow all over the place and float on the water surface before mixing. Granular works best.
    Matt
    Apr 2014
    Lumberton,nc
    20
    Thanks for the replies everyone!! This helps in my decision
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I've been using the Boric Acid route for a couple years now. Get it from Duda Diesel. Why?
    Getting the Boric Acid (grandular) is a little more expensive, but it's pretty much a one shot/one shop deal and don't need to use Muratic Acid. I couldn't get enough borax from one store. Needed to run around or have them special order enough. Then you've got all the boxes to throw away. (I'm lazy.)
    Good luck with what ever you decide.
