Thread: gas heating system
    Houston, TX
    1,101
    gas heating system
    Hello to All,
    we used our spa/heater for the firm time this Sat night. Here's the info:
    Summary
    Via remote and operating manual, the Spa icon was instigated, then Heater 1, then Blower [Aux 2} once the water started to get warm. The water become warm med-hot, then the icon on the remote for Heater 1 turned off and would not turn on again for the next 25-30 minutes regardless of how many times the remote button for Heater 1 was pressed. When pressing either the Blower [Aux 2] or Gas Fire Bowls [Aux 4] or Scuppers [Water Feature] or Lights via remote, they all worked fine. When the SPA was not producing any additional warm water, the Pool icon was pressed from Spa and the valves changed and Filter was pressed to verify VSP changed from Spa to Pool correctly. No breakers were tripped when examining the control panel which was a prior issue. Note, spa temp is currently 100F, which at above 104, the heater would not work and the icon would not display
    Is there a potential problem w the heater since it would not reactive even when initiated by the remote control?
    Thank you,
    tstex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Jun 2012
    western NY
    1,560
    Re: gas heating system
    Does the heater not come on at all now or will it come on once the water temp drops a bit? I would suspect that at 104 there may be a limit to keep the heater from getting the water any hotter.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2015
    Wildomar, California
    423
    All pool heaters on the market today will not heat above 104; preset by the manufacturers. Also, check to make sure that the actual water temp on the heater and your controller are the same They are in series so that the temp on the heater, if lower than your controller, will shut off first.
    Houston, TX
    1,101
    Sorry, need to clarify that the current spa temp is set at 100. The manual states that if temp set above 104, the heater will not work and the icon on the remote will not be highlighted or come on either. I never adjusted the spa temp from 100.
    It seemed once the temp reached max heat, the water started to feel less hot over the next 25-30 minutes. During this timeframe, I tried getting the heater to come-back on, but neither the heater icon would come on nor the heater itself...I did not get a temp reading on the remote before we went inside and shut it down...should have done that.
    It was about 10:30 - 11pm Sat night w an ambient air temp of 78-80, 700-800 gal spa and Cl-based water. Once the water reached 100, I guess the magic question is how long would it stay at 100 before hitting 99 and re-initiating the heater? Later tonight I will do exactly the same thing, then once 100, I will monitor the temp and see what happens to the Heater function, and/or once 100, wait 5 mins and increase Spa temp to 101-102 and see if heater kicks on. I will post back w results.
    Sorry if I made it confusing and appreciate your feedback,
    tstex
    Jun 2015
    423
    No worries, we just want to help
