Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: endoscopy of skimmer lines through camera
    Jun 2015
    sassari
    8
    Lightbulb endoscopy of skimmer lines through camera
    Hello all, I've got to check two skimmers lines, at the moment the proprietors closed those skimmers as someone in the past (years) suggested to do it so as they were not working properly. Causes were never investigated, maybe they told them that the line tubes were cracked but really that was only an hypotesis, last week those skimmers were turned on again in error and lasted on for one week, the pool didn't lose water but the skimmers do not suck anything. I believe they could be badly clogged or something. So I got an idea, I bought this camera off ebay , I want to insert it in the lines so to inspect the tubes from the inside.
    What do you think?
    Jun 2014
    15,180
    Re: endoscopy of skimmer lines through camera
    I think if it works, you'll be receiving requests from many other TFP members to come troubleshoot their plumbing. I hope it works for you, and definitely keep us posted. Good luck!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Sounds like a good plan. The most common issues I've seen with skimmers besides cracks and leaks is collapsed flex pvc plumbing. If the line is clogged try a drain king or plumbing snake to clear it.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    If the pool had pucks in the skimmers you may also encounter this kind of damage:
    Skimmer plumbing pipe damaged from placing chlorine tabs in the skimmer leaf basket.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
    DFW, TX
    24,497
    Ewww, another reason to hate the puck!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by swoopman View Post
    That album is a great "why not to put tablets in the skimmer" testimony.
    Isolated Spa - 345 Gallons
    Jun 2014
    15,180
    Curious, if you go from the skimmer to the pump basket for an endoscopy, then later if you go from the other direction does it make it a colonoscopy? Sorry - couldn't resist.
    Jun 2015
    sassari
    8
    You mean the pucks create that kind of damage? in PVC tubes? At the moment they are putting them in the two working skimmers.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Quote Originally Posted by chrizx74 View Post
    YES! When the pump isn't running the pucks dissolve creating a high concentration of chlorine. Then when the pump is turned on, the pvc is exposed to that concentrated chlorine which over time leads to this damage. I speak from personal experience - before finding TFP
    TF-100 Test Kit
    Feb 2014
    Central Minnesota
    5,080
    Get those pucks out of the skimmer! If you run the pump 24/7 they could be used, but that's just a waste of power. The problems arise when the pucks are dissolving in a stagnant skimmer.
    # Sent from mobile device. Beware of brevity and spelling errors!
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    well, I do not know if it is a common problem for those who use pucks in the skimmer, but I can guess as to the reason so many do: in my pool manual from the manufacturer it in fact says it in B&W that the skimmers are designed for placing chlorine tabs in them and it is absolutely normal to do so and won't result in any damage.
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    Jun 2015
    sassari
    8
    So one shouldn't stop the pump until the puck is completely dissolved.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    So run pump 24/7? Once it's dissolved there is no longer chlorine being added to the pool.
    TF-100 Test Kit
    May 2015
    Killeen, Texas
    89
    Just get one of the floating baskets and put a puck in it. See how many seasons you have your floating basket. They "rot" out even though they are constantly in the water.
    Jun 2015
    sassari
    8
    Mistery solved. There' s a completely broken tube under one skimmer. It's divided in two completely.
    22,551
    Did you use the camera to find that?
    If so, how did it work?
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    338
    Huh. I just had a guy come over who said I should switch from liquid 12.5% to tablets, because it's better on the equipment and liner. Guess not so much?
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    My SIL's intake and outlet hoses cracked after 2 years due to her using the tabs in the skimmer. They are still there, so I ma guessing it's almost time for the second set of hoses to go. She thinks I'M the crazy one, lol.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by MitchRyan912 View Post
    Definitely not so much. You can do the same damage with 12.5% bleach if you pour it directly into the skimmer with the pump off and leave it that way for hours, which is essentially what happens when you leave a puck in a stagnant skimmer. However, if you add 12.5% as recommended (SLOWLY in front of a return with the pump on) and be as fussy as me and actually brush the bottom of the pool after adding bleach, there's zero risk of damaging pool surface or equipment.
  20. Back To Top    #20
    Jul 2015
    Madison, WI
    338
    Quote Originally Posted by JVTrain View Post
    I hadn't thought of brushing the pool afterward. I don't brush very often, as I vacuum at least once if not twice a week.
