Results 1 to 10 of 10
Thread: Results!
    Jul 2015
    Dothan, AL
    11
    Results!
    First pool test after joining TFP
    7/09/15
    CYA- 40
    TA- 100
    FC- 4.5
    PH- 7.5
    Salt- 3620
    After loading up CYA and salt a week ago
    7/19/15
    CYA- 70
    TA- 80
    FC - 3.5
    PH - 7.2
    Salt- 3930( Yeah my Jandy Aquapure SWG calls for 4000 optimum)
    CH- 225
    Water has been looking better each day since last week. On the down side I can see each bit of trash on the bottom now.
    After this test I increased my SWG output 1 level to hopefully hit the FC, if not I'll increase my filter runtime.
    I received a outlet fountain I ordered from Amazon last week and installed it a couple of days ago. Started running it today so
    hopefully I'll get the PH up in a couple of days.
    Glad I found this site!!!!Thanks!!
    21K gallon In ground saltwater, vinyl liner, Built 09/14, Jandy sand filter, Jandy FloPro pump, Jandy Salt chorinator, Polaris
    Hot Springs Relay hot tub, 360 gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Results!
    PH at 7.2 is OK, let it rise on its own. 7.2 to 7.8 is OK.
    3.5 ppm FC is too low, 5 is the target and it should be kept at 5-6 ppm at all times. I keep mine a little higher than that, usually 8ish. I am not interested in SLAMing my pool ever again!
    Apr 2015
    Quinlan, tx
    811
    Re: Results!
    Quote Originally Posted by pooldv View Post
    Agreed!
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Jul 2015
    Dothan, AL
    11
    Re: Results!
    Thanks guys! I'll keep an eye on my FC this week to see if the SWG adjustments work
    Jun 2014
    15,221
    Re: Results!
    Always good to see someone eagerly using the TFPC methods and enjoying the results.
    Apr 2015
    Quinlan, tx
    811
    Re: Results!
    Does your SWG have a timer? People seem to have better results if you do bursts of chlorine rather than running SWG all at once. Currently my pump runs 7:30-10 am, 12-5, and 7:30-9:30 pm. That way I start the morning with it making chlorine, have it work during the heat of the day, and then stock it back up before the sun goes down. My pool is in full Texas Sun almost all day. In June, I ran the pump 7 hours a day, and before that only 5. This is my first summer of TFP so I'm still figuring out what's and happen to be a bit of a "helicopter pool mom." I do NOT want another algae outbreak!
    Lisa P.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Results!
    Quote Originally Posted by joemc View Post
    this is not how you should do this...add bleach/chlorine to get your FC to the desired level and then make sure you SWCG is set to just maintain the level. best way to zero it in. if not, you are setting your SWCG higher amount, when it hits the level, then you have to recalibrate again to try and maintain. just get it there and then maintain it. don't let it fall below the minimum level
    Quote Originally Posted by Pogueld View Post
    Lisa P.
    it shouldn't matter, as long as your FC never goes below the minimum. test your FC right before your SWCG comes on, that should be the minimum for the day.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Apr 2015
    Quinlan, tx
    811
    Re: Results!
    Quote Originally Posted by DaninFLA View Post
    This is not how it works for me, just sayin', just because the SWG is on, it doesn't maintain the FC it started with. It depends on organics in the pool, UV, etc. My levels have been at 1 before in the evening when they started off much higher in the morning. So, personally, I wouldn't assume it is maintaining without testing throughout the day until you get the feel for your pool. I was advised by moderators on the forum to divide up my pump time throughout the 24 hours for a more consistent chlorine production. Assuming my SWG Was maintaining is what got me in trouble in the first place.
    At various times throughout the season, I have had to adjust the percent output and the run time. For example, yesterday, my husband mowed, which puts more organics in the pool from blow off and we were going to be swimming (more organics in the pool), so I bumped up the SWG to 75% to compensate. It worked. I has at 7.5 at the end of the day. If I hadn't adjusted, it would have been too low with the extra organics in the pool that day. My goal is 4-6 for my 80 ppm CYA. I try to target 7-8 so it never drops below 4. I get insects, frogs, etc in my pool overnight sometimes.
    Lisa P.
    Jun 2015
    Raleigh
    357
    Re: Results!
    Agree with everyone....I balanced my swg pool with bleach only first...then introduced the swg to make sure it would maintain. Start out aggressive. I'm running 8 hours at night at 75% and 4 hours during heat of day at 75%. So far I've been gaining .5 ppm per night so I'm close to what my pool needs. I'll start reducing the % until I'm maintaining and not gaining. I plan to keep pump on slow at night and mid range for four hours during peak swim time for skimmer.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Apr 2015
    Quinlan, tx
    811
    Re: Results!
    Sounds like you are on the right track. You will learn your pool's personalities and needs. Good luck!
