Thread: Safety of SWG
    Safety of SWG
    My dad is wanting to go the SWG route, but his wife is leary, since there is electricity flowing through the water. Of course on the surface everyone knows electricity and water don't mix, but I'm sure her concerns in this application are unwarranted, right?
    Has anyone seen anything out there that addresses this concern that might make her more comfortable with the SWG approach?
    Arizona
    924
    The pump and lights are already electric, so why would she be concerned about the SWG? They of course are built to be around pools just like the pumps and lights, with proper installation, there should be no worry.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Also, an SWG is only 24 volts which is not nearly as hazardous as 115v or even 230v that some pumps use. Not that this really matters since everything is grounded. Electricity takes the path of least resistance to ground. So if anything shorts or gets an open, electricity has a path through ground.
    Also, since the cell plates are very close to one another, the electricity will only travel to the opposite plate. I believe there is also a grounding plate in the cell in case anything gets disconnected.
    Mark
    Quote Originally Posted by mas985
    Being grounded is the important thing. Grounding the shell of the pool light provides the shortest path to ground should something go awry. Same is true for your pump, it's shell should be grounded so you don't get shocked.
    It isn't voltage that kills, it is current. Voltage plays in this because of Ohm's Law which states that voltage is equal to current times resistance. V=IR. The problem with humans is that R is not constant. Moisture lowers your resistivity. Salt lowers the resistivity of water. And if you remember your science you can make a battery out of salt water and 2 electrodes. The original 220V was based on experiments with pigs and was thought to be a safe voltage. Contact with 220V should knock you away from it. Some thought that 110V would be better, but it has the annoying ability to make you hold on to it if you touch it. And 24V is supposedly the lowest voltage that will cause you to feel a mild shock on dry skin. Get wet or sweat and all of these voltages can become much more dangerous.
    So now you should be able to answer those Trivia Challenge questions.
    16x32 vinyl inground pool
    2 speed 1hp Hayward Super Pump
    If everything is properly installed it will be very safe. There should be thick wires connecting the SWG, pump, heater, and the bonding grid inside/under the deck. These wires keep everything that touches the water at the same potential, preventing shocks. Technically this "bonding" system isn't the same thing as grounding, but it does the same job keeping you safe.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    24V DC, correct? If so, it's a much different animal than 110/220 VAC that feeds a pump. You're still correct in your statement though, it's much less hazardous than 110/220 VAC.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
