Thread: Now what? Help with chemicals, please
    Jul 2015
    Shannon, IL
    7
    Question Now what? Help with chemicals, please
    We have had our intex pool up now for a couple weeks, I have had a sock of stabilizer granules in the pool for at least 10 days now. Received the suggested test to upgrade the Taylor kit to the 2006, I just tested with the following results:
    PH- 8.0
    FC-.35
    CC-0
    TA-340
    CYA -0
    I have been adding 8.25% bleach daily. I know from the last post, TA is the last thing to adjust. But between FC and TA, what is the order of importance to adjust? My water is clear and kids have been swimming without complaint. I'm not sure what is next... Thank you!
    22" x 52" AG Intex pool, ultra metal frame 2015
    10,400 gallons, full sun
    krystal clear model 633 pump using a type B cartridge filter
    Filled with well water, using a Taylor K-2005 test kit
    Northern IL
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,492
    Re: Now what? Help with chemicals, please
    Ph down will work on getting the TA down.
    Get FC up and feed your pool every day so the FC stays in range.
    Make sure you wait 30 mins between adding muriatic acid to bring the PH down and the bleach to bring the FC up.
    I am going to post some links just in case you don't know how to do what I am telling you.
    http://www.troublefreepool.com/calc.html
    I hope this helps!
    Kim
    30,419
    Far and away your biggest issue is you have no chlorine in your pool. You must keep it in there at all times.
    Is it all dissolved? How much did you put in? Why do you think your CYA is still testing at zero if you put that in there. You CYA is sort of a secondary issue but you cannot keep chlorine in your pool until you get CYA in their to protect the chlorine from the sun.
    Have you read "The ABC's of Pool Water Chemistry" up in Pool School?
