Results 1 to 10 of 10
Thread: Top panel blew off IIntelliChlor IC40
    Apr 2008
    StL, MO
    49
    Returned home from weekend getaway and when I went to close valve for main drains before vacuuming I saw that the top panel of my IC40 had blown clean off. Noticed a black mark on the inside of the white cover that looked like an electrical burn and another burn on the exposed black membrane that is beneath the white cover. Strange thing is the cell was still reading the salt level and showing output when I went to Diagnostics on my EasyTouch. Cycled the breakers but the cell's indicator lights are out.
    Thoughts? Haven't checked the fuse in the power center yet. Ugh!
    Re: Top panel blew off IIntelliChlor IC40
    Sounds like you're going to need a new cell. How old is it?
    Can you post a picture?
    Support the site
    Apr 2008
    StL, MO
    49
    It turned 3 in March. I'll post photos shortly.
    Apr 2008
    StL, MO
    49
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Wow! First time I've seen that! Bummer!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,461
    Sorry, but it is time to bend over and kiss your IC40 good-bye...
    I take care of an electronics repair department (Nothing to do with pool stuff) but based on personal experience with things that look similar to this, I'm pretty sure that it is toast.
    I have seen this happen before. In the case I have seen there was water intrusion into the electronics. It looks like this is a similar situation.
    Time for a new cell.
    Support the site
    Apr 2008
    StL, MO
    49
    Thanks both. I was thinking the same thing. Again, ugh.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    You didn't have a recent thunderstorm did you?
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Apr 2008
    StL, MO
    49
    Correction, I replaced the cell last June. I've replaced so much Pentair equipment since our pool was built in September 2007 I can't keep it all straight. Pentair has agreed to replace the cell out of warranty!
