Thread: leg slippage
    Jul 2015
    Marietta
    2
    leg slippage
    I just installed a 24' x 52" Intex round metal frame pool. I made sure the legs were level and filled the pool. After a rain overnight I found 2 legs out of level directly across from each other and the legs are bowing outward as if the legs had moved inward. On one side it is about 1" high for about 3 feet and on the other side it is about 1-1/2" high for about 3 feet. Basically it is just high exactly where the 2 legs moved. How big of a problem is this? Should I try to jack these 2 points up and put something under them.
    24'x52" round intex metal frame pool saltwater using chlorine generator. First time pool owner
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: leg slippage
    Can you post a picture?
    Jul 2014
    Oakbank, Canada
    389
    Re: leg slippage
    I would not worry too much right now, just keep an eye on things if they get worse.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jul 2015
    Marietta
    2
    Re: leg slippage
    This is my first pool and it may be ok, just thought I would ask people that know more than me.
