Thread: Bought a cleaner, need some advice.
    Jul 2015
    Rebecca GA
    2
    I'm new to the forum. Hi, all! Bought a Wanda the Whale, Hayward AG pool cleaner. Instructions were not all that informative, but seemed easy enough. I have a 26x52 AG pool,14,000 gal capacity. Pump came with pool. It's a Krystal Clear Filter Pump w/2500gph. It seems like there isn't enough suction to make the cleaner work.
    Is the filter/pump not big enough or does anyone know if there is an adaptor or something else I need to make this cleaner work. Pool and filter are only one year old.
    26' x 52' Intex Ultra Frame AG vinyl pool w/ Intex Krystal Clear 2500GPH Filter Pump w/timer. 14,000 Gallon water capacity. Pool is filled by well.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    Re: Bought a cleaner, need some advice.
    I have to close the valve on my bottom drain AND turn my pump on high to make my Wanda work. If I do not do either one it does not work so...............I am guessing your pump is not big enough to run her You can see my pump in my siggy.
    I wish I had better news for you. I love my Wanda.
    Kim
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Hi, Wanda comes with a restrictor that may need to be used or not. You may have to try it both ways. You need to remove the bottom plate and you will see the press-in restrictor. This cleaner needs about 30 gpm to operate properly. The 2500 gph works out to about 41 gpm. This would be with a clean filter. As the filter gets dirty the flow will diminish. I have not seen good luck with this pump in the past.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
