Results 1 to 10 of 10
Thread: new sand filter: brown water staight into the pool!!!
    Hi guys...
    my first day on cleaning our brand new pool has been LONG and frustrating!!!
    We are doing all by ourself, we DID all by ourself (from digging to concrete etc...)
    No builder to ask to... as today is Sunday no pool shop to call either.
    Well... the sand was in the filter since Yesterday but didn't start filtration as the water level was too low.
    Today was the day! Switched on and... inlets were pouring brown water into the fresh filled pool.
    We had to back wash for 10 long minutes before the water got clear!
    Of course by that time the water level in the pool was too low again!
    Now... before I go to kill someone at the pool store:
    is it normal that brand new sand comes dirty???
    We really didn't expect that!
    Thanks for your comments!
    16.000gal, 8-16f width x 50f lenght. 3 levels depth 1f, 2f, 4-6f. White plaster walls with flat stones floors.
    Sand filter Astral 600, 1.5HP Astral Pump
    Zanzibar is a hot, humid and windy Island, summer all year round
    Chemicals and equipment supplies are very limited.
    Apr 2013
    North OKC Area
    300
    Re: new sand filter: brown water staight into the pool!!!
    Yes, you must backwash and rinse new sand. It is usually in the instructions for the filter.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    very common. It should be RINSED very well before turning it to filter. You can also backwash then rinse. You should always rinse after you backwash,
    Kim
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Well others said it, so just +1. Backwashed+rinse+RTFM
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    Apr 2015
    Quinlan, tx
    811
    I learned something new today! I didn't realize that. Good to know if we ever replace the sand.
    Good luck on refilling and getting your pool water balanced!
    Lisa P.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Thanks everybody!!!
    I actually did backwash and rinse... so after panic I manage myself into the right way.
    But I wanted to know if there was a mistake from the shop...
    Good... I don't have to kill anybody!!
    Hi Morzh...
    can you please tell me what RTFM stays for?
    Thanks for your time!
    Apr 2015
    Quinlan, tx
    811
    Quote Originally Posted by kamili view View Post
    Thanks everybody!!!
    Excellent - your pool would surely be a mess if you went to jail - teehee!
    Lisa P.
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    RTFM is one of those Army/computer lingo meanig "Read The Flaming Manual"
    Never heard it?
    Installation instructions for the new filter usually remind to backwash and rinse the sand (mine from Hayward did).
    May 2015
    Chickasha, OK
    184
    I was assuming 'RTFM' meant 'Return To Filter Mode'...
    25,000 gallon freeform gunnite/plaster, built in the 1970s/80s; Sta-Rite 9463004 575-lb. sand filter; Sta-Rite DuraGlas/Max-E-Glas (P2RA5F-125L) single-speed 1.5 HP pump, manufactured 12/1993 (1M93M).
    Helpful links: TFTestKits; Pool School; ABCs of Pool Water Chemistry; Chlorine/CYA Chart; PoolMath; SLAM - Shock Level And Maintain
    Apr 2015
    Quinlan, tx
    811
    Lisa P.
