Thread: Drops question
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Drops question
    Okay the instructions clearly say drop one drop at a time swirling between each and that has been what I have been doing. On tests that yield a high number of drops and you have a track record of the test results is it okay to add multiple drops in the beginning until you approach the color change threshold or will this affect the test results? Example CA if your value is 300 or so can you add 10 drops twice swirling between each then drop 1 at a time? Or TA if your value is around 100 can you add 5 drops right off the bat then go one at a time?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Drops question
    I put them in a bunch at a time until I get close to the expected value. I've never seen any effect.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Drops question
    I do the same as JohnT.
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Drops question
    Ditto to what John said!
    On a CH test I reasonably expect to be ~ 300, I'll add 20 drops first, swirl for 30 sec. and then add 2 drops at a time until I get close to the end point, then it's drop by drop until the endpoint holds (adding 2 at a time - even if you hit the endpoint after adding 2 drops - your within the margin of error for the test, so you've still got a good number) If somehow you overshoot adding 20 drops, just repeat the test and only add 10 drops at first then 2 at a time and then drop by drop.
    Luv& Luk
    -Ted
    Re: Drops question
    When measuring very high CH levels you might want to use the alternate test directions. They will allow each drop to count as 25, which means fewer total drops.
