Thread: looking for suggestions on building a step
    Jul 2012
    Chicago, IL
    358
    So, because previous owners built the deck over the top railing, I had to cut it back when it came time to replace the liner. As you can see from the pic, the pool railing is now begging to be stepped on. I would like to attach some sort of step to the facia, just above the top rail. The facia is a 2 x 10 anchored to the deck frame, so should be plenty strong there. What is my best bet for support? Metal brackets? Build it out with wood? Thoughts?
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: looking for suggestions on building a step
    a 6x6 cut to length and using anchor bolts to the fascia board would probably work.. it may be a lot of force and twist every time someone stepped on it though... You may have to anchor the fascia board better to handle the stress..
    Jul 2014
    Oakbank, Canada
    389
    Maybe just build it out with a 4x4 lag bolted into the fascia board.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jul 2012
    Chicago, IL
    358
    Thanks, I am hearing lots of votes for building out with wood (as opposed to brackets) so will first take every opportunity to better anchor the fascia to the frame and then spend some time in the screw/bolt section of home depot.
    Jul 2013
    Fletcher, OK
    3,353
    Just thought of some thing, you could use some 1/4 inch stainless steel and make 2 identical J type hooks.. Anchor 1 side to your deck and the U under the 4x4.. For support
    May 2012
    Montville NJ
    545
    Cut the fascia out at that spot. Sister new joists to the existing joists under the deck. Use carriage bolts, washers, and nuts. Have the sistered joists stick out to the edge of the pool. Put decking (and fascia) on the new section.
    Now your deck extends out in just that spot. Then, when you have to get to that top cap again, you go under the deck, and because you used carnage bolts, not lag screws, you can unbolt that section, slide it out towards the pool, and remove it. Then after you do what you have to do to the pool, you can slide it back in.
    If you sister it for 4 feet or so under the deck, that should be quite sturdy. You could even go overboard and attach a 2x4 on the bottom of the existing joist, so the new sistered joist has a bearing surface to rest on when it is in place.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
