Results 1 to 9 of 9
Thread: low CH
    Jan 2015
    Anthem, AZ
    188
    low CH
    I need some assistance in low CH. I was testing about 200 after a 50% drain of my pool. Went to the pool store and asked for CH+ or calcium +. They gave me 4lbs of some stuff, I can't remember the name, in blue bucket. I've looked at pool math and googled calcium chloride but can't seem to find the friendly bbb version?
    My readings after using the CH+ from the pool store is now 175 which makes me kinda concerned either with my test methods or of what they gave me.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: low CH
    You need to post up what it is the pool store gave you. Look on the bucket and tell us.
    As far as calcium goes, you might be able to find calcium chloride in the concrete department at Lowes or Home Depot, but then at this time of year, maybe not. Its used in concrete mix to keep the water in the concrete from freezing in cold weather constructions.
    There is not a grocery store item to use for calcium. Some brands/ mixes of Ice Melt, which you sprinkle on the side walk to melt ice is acceptable, but I doubt you'll find any of that this time of year either.
    Divin Dave,
    Apr 2015
    Tulsa, Oklahoma
    48
    Re: low CH
    I bought a 50lb bag on Gemplers for around $50. My CH is at 100 and I want to bring up to 300. Wondering the best way to apply such a large amount.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: low CH
    More info on adding chemicals, what they are and what they do here,
    Tell us the current CH in the pool and the CH of your fill water. If you are around 200 and your fill water is too then I wouldn't add more because CH will increase as you replace evaporated water. The calcium stays in the pool when water evaporates. The only way to lower CH is to drain water from the pool and replace it with water that has lower CH than the pool water.
    What test kit are you using?
    Aug 2014
    Shallotte, NC
    693
    Re: low CH
    Most likely, Calcium Chloride..... if you live in an area that gets a lot of ice and snow, you will find de-icer. Otherwise, I think it is just easier to buy from the PS...
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: low CH
    I usually have 300lbs of DowFlake Calcium Chloride on hand for ice melting- great for CH rise
    I think the OP is just north of Dallas, and they got a bunch of snow this past winter, As DD said at Home Depot & Lowes, 50lb bag of Calcium Chloride flakes for under $20.
    If this coming winter is like your last, you may want to stock up.
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    DFW, TX
    24,485
    Re: low CH
    Quote Originally Posted by EVChargeGuy View Post
    It better NOT be!
    Aug 2014
    Shallotte, NC
    693
    Re: low CH
    I really envy some of y'all that can find 10%-12.5% chlorine and other things. NC doesn't seem to have any 10%-12.5%, except 1 gallon bottles at pool stores for $$$.$$. Here at the beach, ice melters? Nope.
    Jun 2014
    Long Island, NY
    340
    Re: low CH
    Quote Originally Posted by pooldv View Post
    It better NOT be!
    This is me driving from Mt Pleasant Tx late Feb 2015
