Results 1 to 8 of 8
Thread: No Need For Acid
    Jun 2015
    Houston, Tx
    19
    No Need For Acid
    So, I have been following TFP for about 2 months now and I have been loving it. Ever since my SLAM I have to add between 1/2 gallon and 1 gallon of 8.25% everyday and the pool has stayed crystal clear.
    My question is why have I not had to add any acid yet? Most of the post that I read say that once you get into a consistent pattern most people have to add a few cups of acid every week. I keep on checking my pH and it bounces between 7.5 and 7.8 and I have not added any acid.
    My only other thought was that it could be the water that I have to add to keep my water level consistent. After a full day of pool use I usually have to replace about a half inch to an inch of water.
    My numbers from my test this morning are:
    CC:0
    FC 3.5
    CYA: 35
    TA:100
    CH:350
    pH: 7.8
    Thoughts?
    In ground 30,000 gallon rectangular plaster/pebble pool, hot tub with blower, 2 HP Pentair WisperFlo Single Speed Pump, 420 Pentair Clean and Clear Plus Cartridge Filter, Pentair Rainbow 320 Chlorinator, Easy Touch Control System, Pentair 400K BTU heater, Interfab G Force Slide with dedicated 1 HP pump, Travertine Decking, CoverStar automatic pool cover
    22,553
    Re: No Need For Acid
    It's not odd at all not to have to add acid to a pool. My pool is over 6 years old and I haven't added a gallon of acid in the whole time. My pH stays right at 7.5.
    Sep 2013
    Connecticut
    728
    You're lucky to have nice stable pH - probably a conjunction of various factors, including your TA.
    Not everyone has to add acid. For example, our pH drifts gradually down (using only bleach to chlorinate), so I periodically add a few cups of borax to bring it up. That (i.e. pH dropping) seems to be somewhat more common in New England than in other parts of the country.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Be happy!
    You have not had to add any acid, because your pH has found a happy place with your TA. The TA effects the rate of pH rise. A lot has to do with what the TA of your fill water is too.
    It happens on occasion that its gets just right.
    I havent added any MA in over a year.
    Divin Dave,
    Jun 2015
    Houston, Tx
    19
    Thanks for the responses...I'll just consider myself lucky.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have never been so lucky. I lived in New England where I always battled low pH, now I'm in Tucson where my pool has a constantly rising pH. Lowering the TA only works for a little while, until replacing due to rapid evaporation with highly alkaline water brings it back up. Count yourself lucky.
    chiefwej
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    What is the pH of your fill water ? Mine is 7.8 to 8.1, but the water where my son lives comes out of the tap at 5.7 ! That would make a huge difference.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Since finding my pool's sweet spot with TA and borates 3 seasons ago I haven't had to add a drop of acid, even with; my stays at 7.5-7.6 all season even with chlorinating with a SWCG. I do have to raise pH a little at spring opening though (I use borax to do so).
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
