Thread: New build in Katy Texas
    Sep 2012
    Mcallen, Texas
    25
    Hello,
    I in need of a reputable pool builder in Katy Tx. Any suggestions for those Houston members? What should I expect to pay for a pool build with no hot tub? Thank you in advance.
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Re: New build in Katy Texas
    I would talk to this guy.
    New Pool Build - Katy, TX
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    That's a very open ended question fab68.
    They type of pool, size, finish, coping, deck and any features that it has.
    The choices are very diverse and you have to start somewhere.
    What are the site conditions; slope, septic relocation, tree removal, access?
    Down here most do gunite pools.
    Do you want part of it deep enough to dive into; 8-9' Or will it be sport depth; 3-1/2 - 5-1/2'
    What surface area or volume are you looking for? somwhere to play pool volleyball or more like a spool (bigger than a spa but not quite a pool)
    Not many down here do vinyl liners but they are an option. Otherwise is is plaster or one of the pebble or quartz finishes?
    Do you want Salt Water?
    Will there be rock features; Waterfall, weeping wall?
    Will there be any other sorts of water features; laminars, bubblers, deck jets, Swim Jets?
    What sort of waterline will it have; tile, glass tile, stone?
    What sort of coping; cast concrete, brick bullnose, travertine, flagstone?
    What sort of deck and how much area and will it have more than one level; concrete with rock salt finish/patterned finish/cooldeck finish, paver, travertine, flagstore?
    What lighting in pool; regular LED?
    What cleaner; robot, pressure boosted (polaris style)?
    What filter type; sand, cartridge, DE?
    Do you want heating?
    Do you want cooling?
    Any automation?
    Other stuff; firepit, outdoor kitchen, gazebo?
    Narrowing down just some of these will make any ballpark estimate worth something to you.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Sep 2012
    Mcallen, Texas
    25
    ozdiver,
    No tree removal. It is a flat surface. Gunite would be my choice with pebble sheen. Depth 31/2 to 51/2. The area around the pool would be small. No heating needed. The rest I am flexible. No fire pit .
    Quote Originally Posted by ozdiver View Post
    Any automation?
