Thread: How do I install a drain safety cover
    I have an old Anthony Sylvan inground plaster pool with a 5 1/2" main drain opening. The drain cover is seated on a lip on the drain opening and there are some tabs on the underside of the drain cover that hold it in place through friction. There aren't any screw holes.
    How can I install a safety drain cover that needs to be screwed down? I would like to find a solution that doesn't require draining the entire pool. Is there some sort of epoxy that I can use to attach the base of the safety drain to the pool floor?
    This is the drain cover that I bought. Paramount SDX High Flow Safety Drain Cover - Universal Retro Version - 004-192-2214-01 - www.instockpoolsupply.com
    Thanks.
    15,000 gallon unpainted plaster. Sand filter. Polaris 380.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How do I install a drain safety cover
    I'm not really sure, but perhaps a bump will get you some help from one of our ITI guys. Perhaps YouTube can help....Good luck on it!
    Essential Links:
    May 2015
    Kennesaw, GA
    29
    If I understand your question, you might consider using a quality silicone caulk to bond the safety cover to the drain cover. For example, remove the current cover, put a healthy, large bead of the caulking around the entire edge of the drain cover where the safety cover will be located, and place the safety cover over the current. Be sure to allow the silicone to harden before replacing the two - e.g., as one bonded unit.
    Just a thought. Hope this helps.
    Leo In Kennesaw, GA
    Older 40x20 rectangular pool
    38,000 gallons
    Vinyl In-ground - Buster Crabbe
    Pentair Chlorinator - Salt - SWG
    Jun 2015
    Wildomar, California
    423
    Actually you might try using a/b or a similar epoxy putty which you can pick up at any pool store. It cures underwater and lasts a while. I personally don't know of any silicone that works underwater, but that doesn't mean there isn't any.
    I could bond the safety cover to the existing drain cover but I would like to have a way to secure it down. Worst case, I could probably get a diver to drill some holes and epoxy some screw sleeves in.
