Thread: Introduction
    Jul 2015
    Broken Arrow, OK
    3
    Introduction
    Hi! I'm Jess99. I've had our pool for 12 years. Never had any trouble maintaining it until last year, but got it under control pretty quickly with
    the help of Leslie Pool at the cost of an arm and a leg. I am now having trouble with algae and am having a problem getting it under control.
    I've already learned a lot by reading posts on internet. I am curious what you are calling a slam and how to do it.
    I have a 15x35' preformed plaster in ground pool. Hayward sand filter. Approximately 24,000 gal water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Introduction
    Welcome!
    SLAM means Shock Level And Maintain. The pool store shock is usually a one-time mega-dose of chlorine that might do something, but it's not a permanent solution. Our method is sustained for several days and when it's done right and you maintain adequate chlorine levels, it might be the very last time.
    Remember, it's a battle to the death. You don't just knock the algae down and call it a win. The algae will get back up. No, you knock it down and kick it again and again and again so it can't get back up and eventually it dies.
    The detailed instructions are here: Pool School - SLAM - Shock Level And Maintain
    Other people who have done it successfully and usually have pictures to prove it are listed in this thread. Most recent is last: Recovering my old inspirational links - Page 2
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Introduction
    Richard covered the SLAM, so nothing to add but a warm welcome to TFP!
