Thread: Choose the right filter
    (Moved to correct section of Forum by TFP Moderator.)
    It is important to choose the right filter for your pool as the filter is the heart and base of your pool. Make sure the filter you install is able to effectively handle the amount of water in the pool and circulate the water at least very 24 hours.
    The type of filter will also play a vital role in the amount of time, effort and expenses spent on keeping your pool sparkling clean.
    I hope this info helps you.
    Re: Choose the right filter
    Getting an oversized filter can be a big help. A large filter reduces the amount of attention you will need to pay to the filter and helps make the entire system more efficient. Other than that, what kind of filter you get doesn't seem to make all that much difference. Each kind of filter has it's pluses and minuses, but they are minor compared to other work and costs associated with maintaining a swimming pool.
