Results 1 to 14 of 14
Thread: Where to put pool lights
    Jan 2015
    Phoenix, AZ
    27
    Hello,
    We're currently really close to getting started on our pool dig, and have one final open before we can begin. Where to put the pool light? If you look at the picture below, the yellow dash is where our pool designer placed the one light for the pool. My wife is concerned that if she's swimming laps, she'd be swimming 'into the light'. We talked to the builder, and he said if we put lights on the side, we'd need two of them to get adequate coverage. He also said that we could do a single light on the angled portion of the pool that would also work, but this would be pointing toward the house.
    So what would you guys recommend?
    yellow is the current light as it is now
    the two red are the proposed modification
    the purple dash is the pool builder's work around to relocate the light out of the 'swim channel'.
    If none of those, do you have another suggestion?
    Thanks!
    Aug 2014
    Houston tx
    2,524
    Re: Where to put pool lights
    Welcome to TFP! I don't know much (actually nothing! Lol) about pool lights, but I'm sure someone will be along shortly to help you out. Personally, I would go for the 2 on the side, but I'm sure someone more knowledgeable will help.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    You don't want the pool lights facing the house. It is annoying and will cut down on what you see of the pool itself.
    Aug 2014
    Houston tx
    2,524
    Is the house at the bottom of the picture?
    Marla
    Jan 2015
    Phoenix, AZ
    27
    Yes, the house is at the bottom of the picture. See the below for a larger shot.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Two light on the house side. They will be pointing at the waterfalls on the other side, not in the swim lane, not pointing at the house. You can put on on that wall closer to the tanning ledge in the pool and a pretty light pole on the outside of the pool by the hot tub.
    Kim
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    I find swimming toward or away from the light ok.
    Reason being you a not looking forward, you are looking down or to the side when freestyling.
    You are looking forward but above the water when breaststroking.
    That said, if this is a single LED colorchanging light, one will not be enough from either end.
    The red scenario will give the best 'show'.
    You will get great backscatter and reflection off the farside of pool.
    The only spot that will have a slight shadow is off the side of the steps down fron the sunshelf.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jun 2013
    Southwick, MA
    211
    I would do the 2 you show in red and a shallow depth one on the ledge/steps for a total of 3 lights.
    Nice Pool!!!
    24X44 IG Vinyl Custom Shaped Pool, Starite S7M400 Cartridge Filter, Starite Sumpermax VS Pump, built July 2015, TF-100 Test Kit, Pentair Intellichlor IC40 SWG, NG Starite SR400 Heater, Easytouch with Screen Logic, Magicstream Laminars, Bullfrog A7 Spa
    Jul 2014
    New England - MA
    310
    Quote Originally Posted by Carnut12 View Post
    Nice Pool!!!
    I agree with Carnut. I'm not sure what the dimensions of your pool are, but my first impression would be to put (2) where you proposed in red. One sun shelf led pointing the same direction and another in the spa pointing the same direction.
    If this is all Pentair equipment you'd need:
    - 2 intellibrite color led for the pool
    - 1 intellibrite color led spa light
    - 1 globrite color led for the sunshelf
    Thats the exact same configuration I have in my pool...
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    Jan 2015
    Phoenix, AZ
    27
    Thanks for all the replies, everyone. The pool builder has come back and now proposes two color LEDs in the locations shown below. The one in the middle of the pool is a 'big' light, and the one on the steps is smaller. Thoughts?
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Let me understand the topology.
    The shelf is 6-8" deep?
    The shallow end 3-1/2'?
    That light on the sunshelf is going to have a real bright spot on the shelf, and a shadow over the shallows.
    The single large light will not spread enough light laterally to give you a reasonable illumination.
    Apr 2013
    Sacramento, CA
    2,769
    The "best" solution is the one proposed by spool. You need two lights facing away from the house. An additional small light on the sun shelf is better. One in the spa is good too.
    I don't like to swim into a light . Your pool is large enough that it needs two lights.
    Daxton's Avatar
    Jun 2015
    Hill Country Texas
    65
    The lights shining away from house and to key accents you may want to highlight seems best. I found my first pool the light in that position was close to the patio sitting area and we had constant bugs diving to the light and close to our sitting area. The pool we have now is light on opposite side to help draw the bugs away from where we gather.
    Geometric | 11.5k gal | 3.5' - 5' - 4' | Dolphin M500 | intelliflo VSF pump | Pentair quad 80 DE | In Line Chlorinator | 2 skimmers | intelliglo lights 3 | Parajets 3| Pebble Sheen Blue Surf | Limestone coping
    Jan 2015
    Phoenix, AZ
    27
    Great feedback everyone. Thanks again!
