Thread: Do I need to SLAM, or just breathe a moment?
    Mar 2015
    Harvey, LA
    300
    I test my water every day (mostly), and I've noticed that some days my CC hits 1 (or between .5 and 1, since I use 10ml sampling for my tests), but not consistently. Check out my sig for historical test results---I did my test today much later in the day that I normally do (normally I test 9-10AM) as we were out of town yesterday evening and today during the day, and in addition to my results, I had a LOT of leaves, acorns, and crepemyrtle flowers/pods in the pool and in the polaris, so I'm thinking this could account for the slightly elevated numbers...I really don't want to SLAM if it's not a sure issue in the making, but I don't want to discount it either without tossing my numbers out here.
    What do you think?
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Mar 2015
    Harvey, LA
    300
    Re: Do I need to SLAM, or just breathe a moment?
    Update --- I hadn't had a chance to empty the skimmers out before I tested...WOW they were completely full of leaves, pretty much to the point of being blocked off...I think maybe that along with the hard rain storm that came in last night while we were out might explain the variance today, but I'm open to confirmations/counterpoints.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Relax man. I think you're fine.
    All too often we will all see CC's now and then. Most always, there is a good reason for it, such as a full skimmer or whatever.
    If there is any doubt, then just do a OCLT (with a clean skimmer!)
    Divin Dave,
