Thread: Intel 12in by 30ft
    Cassidy's Avatar
    Jul 2015
    Bedford In
    3
    Intel 12in by 30ft
    We just recently bought an index 12 by 30 easy set up pool. Could someone tell me what the best kind of chemicals to use for it? Also how much to use? This is our first pool and my 4 year old daughter is ready to get it set up but I have no idea what to get for it! Thank you!
    Sep 2013
    Connecticut
    728
    Re: Intel 12in by 30ft
    Make sure you have a truly level surface to set the pool up.
    Read
    Pool School - Guide for Seasonal/Temporary Pools
    You can also read more in Pool School if you want a more thorough understanding of pool chemistry - a 1000 gallon pool is not very different from a 40,000 gallon pool as far as basic chemistry and sanitation.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Welcome!
    There's a special article in pool school just for you: Pool School - Guide for Seasonal/Temporary Pools
    If you need help deciphering the terms: Pool School - ABCs of Pool Water Chemistry
    You will need at the very least a two-way drop test kit, about ten bucks. You can buy a bigger and better and more expensive kit if you want, but don't bother with the test strips.
    Did the pool come with any sample products? You will need some stabilizer aka CYA, but your pool is so small that a 4 lb canister is overkill. You won't need a ten year supply. The manufacturer says Water capacity at 80 percent: 1,485 gallons. To raise CYA, two 8 oz trichlor pucks would do it. Some pool stores sell them individually wrapped, or if you have a friend, relative, or neighbor who uses pucks, they'll have a bucket full. Beg or buy a couple.
    Cassidy's Avatar
    Jul 2015
    Bedford In
    3
    Re: Intex 12in by 30ft
    Quote Originally Posted by singingpond View Post
    Read
    No it didn't come with any samples. I am hoping we can get it level enough! I believe from what I read we will need a test kit bleach and cyanuric acid.. We are hoping to get it all figured out and put up tomorrow!
    Cassidy's Avatar
    Jul 2015
    Bedford In
    3
    Sadly we didn't even get to the chemical part. Our ground is just too uneven. After about 6-12 inches we realized it just wasn't going to work. I have an extremely upset 4 year old. Unfortunately we can't really do much to the yard as we are renting so we are going to try and build a platform. Fingers crossed we can get it up and going so my daughter can finally swim in the pool she's been begging for all summer :/
    Orlando, FL
    690
    Quote Originally Posted by Cassidy View Post
    Unfortunately, "level enough" is usually a sign that a lot of work is going to be involved. Sorry that the little one is sad but better safe than sorry. Hopefully, she can get to swim before summer is over. Perhaps, there is a water park nearby that will suffice until the platform is complete. Speaking of platform, remember 1 gallon weighs 8.3 lbs so make certain that whatever platform you are contemplating can hold the weight of 1,485 gallon of water.
    Goof luck and welcome to the forum!
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
