Results 1 to 10 of 10
Thread: Which heater should I buy?
    Jul 2015
    Grosse Pointe Woods MI
    57
    Question Which heater should I buy?
    We live in Michigan and our pool is very cold even on the hot days like today. I'd like to replace our old heater with a new one but need some recommendations on what to buy. The heater that's installed now is gas but does not work at all. I'm pretty handy so I'll probably install it myself. I was thinking of getting a 200BTU heater but I'm not sure where I should buy it from.
    Help?
    11,000 gallon, 26'X11', vinyl, in-ground pool with a Jacuzzi brand cartridge filter and a 1hp hayward pump.
    TF-100 Test Kit
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    Re: Which heater should I buy?
    Go for a Raypak. I would also consider getting a little larger of a unit. Raypak has a 266K BTU and then the next level up is the 400K BTU. Difference in cost is usually about $400.
    I don't recommend buying online but many here in this forum have. Get the one that is electronic ignition. Do NOT get a milivolt unit.
    These are very good units.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jul 2015
    57
    Paul,
    Thanks for the suggestion. I'm just curious, why you prefer Raypack?
    Thom
    Quote Originally Posted by ps0303 View Post
    TF-100 Test Kit
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    I work on pool heaters all day long and I find I repair far less Raypak's than any other brand. I just see them as a more solid choice.
    Paul
    Jul 2015
    57
    Wow really. That's a great insight!
    You also said to not buy one online: why?
    Thom
    Also: What's your opinion on pumps? I may need a new pump soon.
    TK
    TF-100 Test Kit
    Jun 2015
    Wildomar, California
    423
    I've been a Raypak heater repairman for over 25 years. It's the best heater on the market, in my opinion. The obvious advantage to buying local is a warrenty and convenience issue. Most pool companies that would sell you a heater would offer the warrenty repair as well.
    Jul 2015
    57
    Ok thanks guys.
    400K BTU seems like a lot for a 11,000 gallon pool.
    Isn't Millivolt a RayPak heater brand?
    TF-100 Test Kit
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    You just need to consider the amount of time to heat the pool. If you can wait a bit longer then you go with the smaller unit. If you want a faster heat up time, the bigger one.
    Raypak states they will not warranty a unit purchased online. However I am sure you could get them to cover anything that went wrong. However, I hardly see anything go wrong with these units within the normal warranty period covered by the manufacturer.
    Paul
    May 2014
    Lake Geneva, WI
    11
    How much does the size of the gas line matter? We're also looking at a RayPak to replace our existing 250K BTU Laars. We're looking at the 266K RayPak, but I'm not sure if the 400K would work with our existing gas line. I've also seen some talk of a ~333K BTU RayPak. Is that one not sold anymore?
    28,000 Gallon 18'x36' Vinyl IG, Pentair Sta-Rite 1HP Pump, Pentair Sta-Rite 450 sq. ft. Cartridge Filter, Old-School-Looking Polaris Vacuum with Booster Pump
    Jan 2013
    Cleveland, OH
    70
    Agree; put a cupro-nickel Raypak 266BTU (P-M266A-EN-X) on our 16x32, 20K gallon pool 2 years ago. No issues, 1" gas line (hard line) from house, Pro-Flex CSST to connect line from pad to hard line sediment trap coming outta gas valve.
    Replaced a 1998 Purex-Triton MiniMaxx 200K Btu...
    Little bit of retrofit due to gas line/inlet/outlet differences in the heaters but no big deal, can hook up either 120 or 240VAC but otherwise no big deal to install.
    Raypak does still make a 333K btu heater...P-R336A-EN-
    20K gal, vinyl, 1 HP Challenger 2-spd pump, 300 lb sand filter, Raypak 266K BTU, 45M stenner pumpin' bleach
