Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Looking for a cost effective music system for covered patio.
    Jul 2015
    LaCrosse WI
    1
    I am building a 14' x 18' covered patio/deck. I haven't put the ceiling carsiding in yet, so i can easily run wire's and speakers to where I need. I am trying to figure out what the most cost effective way to do this for me is. I am looking for anyone's opinion on options. We normally listen to our music through online like pandora, so I need to have that ability. Depending on cost, I would like to also have the ability to listen to FM radio. We don't have a lot of our own music stored on phones or other electronic storage. I would need to buy everything i need, speakers, amps, etc...I am just at the beginning of researching but I know there are different wifi/ bluetooth/ options. I think wiring speakers would produce the most consistent sound. The part i am most curious on, is what is the cheapest "acceptable" way to get music to the speakers? Also, if i need to get a receiver, what are recommendations to put the receiver in to stay out of the weather as much as possible.... Thanks in advance. Mitch
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Looking for a cost effective music system for covered patio.
    SONOS. Get 1 or 2 Ones and a boost to start and you can expand from there. You can listen to any online source or the radio also online. No wires, just plug it in. Sounds great, super easy, not cheap and easily expandable. Soon you will have them all over your house.
    St. Louis
    12
    I agree with the SONOS recommendation. They are not cheap, but the quality is very good. The SONOS system links to your home wifi network. Two PLAY Ones will give you great sound in that space. They only thing against the SONOS system is that you want to listen to FM stations. Many FM stations are also streamed through on line services that work with SONOS (ie IHeart Radio). You can get these through free accounts. You might just want to confirm the FM stations you want to hear are available through a streaming service that works with SONOS. Each SONOS speaker needs power, so you need to have receptacles near were you want them mounted.
    The other option is to simply buy an amp/receiver to power some good quality indoor/outdoor speakers. Since they are in a covered patio you may not need to worry about outdoor rated speakers. You can simply hook up an iphone/ipod or other smart phone to the receiver using a simple connector that splits the phone/ipod earphone output to RCA plugs and pull in Pandora through your home wifi that way as well.
    25k gallon, IG gunite, Plaster/Pebblesheen (new in August of 2014), Sta-Rite 300lbs sand filter, TF100 Kit
    DFW, TX
    24,502
    Oh, forgot to mention that the Sonos system can be controlled by any and all devices connected to your wifi network, phones, tabs, apple, android, whatever. Change channels, skip songs, volume, pause. Same music on all speakers, different music on each speaker, it is pretty cool.
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    Big +1 on Sonos. I have 4xPlay 5's and a sound bar. Not cheap but I've yet to hear anything that sounds better for the quality vs cost. They're not made for outdoors but I've had 2 of mine outside for more than 3,years with no problems.
    IG 13,000 gal, WetEdge Prism Matrix Indigo Blue, Hayward C4030 cartridge filter, Hayward Ecostar VS main pump, Hayward Tristar VS feature pump, Hayward OmniLogic, Hayward Sense & Dispense (pH only), Stenner 45MPHP22 bleach, Hayward H400FDN Heater, Hayward Color UCL lights, Pentair LED Bubblers. TF-100 XL test kit. Test Results. Build Thread.
    Sonos Connect Amp with a pair of a Definitive Technology AW5500 or 6500 speakers. Sonos is great. I have this setup along with the playbar, sub, play 5, and play 1s. I've had Bose outdoor speakers and Polk Atriums. The Deftechs blow both away. The Amp is in the house with speaker wires routed to the patio. This new will run around $1000, but there is a refurb seller on eBay who sells the Deftechs at about half the price.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    I just went with SONOS myself and bought the older bridge instead of the newer boost at 1/4 the price on evilbay. And you can move those puppies to anywhere you have a 110 outlet. I bought wo 5's to cover the length of the pool mostly and have them grouped, not paired in stereo left and rights.
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    I agree with jmurph but take your situation into account. I have very close neighbors. I feel like I'd be throwing money away because I could never use them to their potential. But if you're nearest neighbor is 2 miles away, yeah, that would be a great setup. For me personally at the volume I can reasonably play, the play 5's are great.
    Jul 2015
    Tempe, Az
    123
    Pandora from your phone and a decent one of the larger Bluetooth portable speakers speakers (I have a Bose, Sony , JBL and Jabra, would recommend any of them.) If your neighbors are close, you want ambient sound, not big booming sound. Don't buy the super cheap ones though, they sound like junk.
    Now, I'm not disagreeing on the SONOS speakers, my employer makes most of the components in them, but they are pricey and may be overkill for what you want. Also, depending where you live, your putting them up, taking them down (they aren't completely weatherproof, and again, pricey,) where the portables you just take inside at the end of the day. And, they are 100% wireless....which in my book makes them even easier.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    +1 for Sonos Connect amp and your favorite outdoor/marine speakers.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Jun 2015
    Florida
    74
    I have 2 outdoor speakers that I wired to my living room receiver. Zone A is living room surround sound. Zone B is outdoor speakers. This is the perfect excuse for your new home theater system.
    10k gallon freeform, 3.5-5ft, Jandy 2 speed 1.5HP, Jandy 200sq/ft cartridge, Jandy watercolor LED, 600sq/ft Travertine Decking, 12x7 ledge w/bubbler and umbrella sleeve, 100ft of baby fence with self closing gate, Pebble Sheen Blue Granite w/ablalone shells, Build Start 5/27/15 and completed on 7/15/15.
    timthek's Avatar
    May 2013
    Philadelphia Suburbs
    37
    Quote Originally Posted by JupPool View Post
    I did the same. I have a projector setup in my basement and I just upgraded the receiver to one with a 2nd zone. I am able to feed it audio from any TV channel, music from my PC, or stream anything via Google Chromecast (or if you have Apple TV, etc). You can use Pandora, Spotify or any online music service. I wired that zone to a pair of outdoor speakers mounted under my deck with a volume control knob. I spent about $400 on the receiver, $250 on the speakers, $10 on outdoor speaker wire, $18 for the volume control, and $40 for a used outdoor Wireless Access Point to cover my backyard in sweet, sweet internet.
    Tim
    20,000 Gallon In-ground - PebbleTec pool surface
    DE Filter with Pentair Whisperflo WF-23
    Pool Season: May 1 - Sep 30; Full Sun
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I did exactly that, got a Sony 2 zone receiver in the house with zone B always on. (So it is easy for the wife). Ran wire from the receiver up to the attic to speakers I mounted outside and connected to zone B. The bluetooth range reaches most places on the upper part of my deck. When we are outside we just connect to the receiver from our phones and it works. Didn't have to worry about outside power, receiver or amp outside or anything. Can play the speakers as loud or as low as we want.
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by Brett_N View Post
    I agree with both points, SONOS is fantastic but you pay the price.
    As far as Bluetooth, that's what I use. iPhone or iPad as source or grab a WiFi stream from my media server(i have over 60GB of tunes) sent to a pair of Ultimate Ears portable Boom speakers 'double upped'. They're battery powered
    The double up allows you to Bluetooth connect to two speakers. My speakers have lasted well past 12 hrs (UE states 15) they cost $199 each. they now have a MagaBoom @$299 UE MEGABOOM Portable Wireless Speaker on Steroids. | Ultimate Ears
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Apr 2010
    East Texas
    9,626
    Please explain this.........."double up"...........technology to me to let you use more than 1 bluetooth speaker. Does it have to be two of the same ones with this "built in" so to speak? Is it a software app, or what?
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    I purchased a Pyle portable PA system on wheels. It has all types of inputs from Bluetooth to RCA to XLR for Microphones. The kids love to use it for Karaoke. I hooked up a Chromecast to the outdoor TV and ran the Audio out from the TV to Pyle speaker. It is on wheels so we just roll it out when we need it. The high heat and humidity in south Louisiana will destroy anything permanently mounted outside. Using the Chromecast allows all of our guests to cast music to the device. If something is already playing the Chromecast queues it like a jukebox. You also get the benefit of having the video play on the TV. We usually cast the music from Youtube which has a huge library of new and old music. It has a 15" woofer so you can compensate low volumes with additional bass to give a fuller sound at low volume levels. It will also play at very high volume levels with no distortion which is great if you have a huge crowd. At under $250 it blows away all my other music gear for poolside music. Check it out at,
    Pyle Pro PPHP1537UB (PPHP1537UB) 15'' 1200 Watt Powered Two-Way Speaker With MP3/USB/SD/ Bluetooth Music Streaming & Record Music Function w/Remote control at Onlinecarstereo.com
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by woodyp View Post
    Woody
    I believe the Double up works only with UE Bluetooth speakers. UE has an App (iOS & android) that is used to configure the speaker(s) sound, check battery level etc & the Double up is part of the app. I think you can mix UE speaker models? Models range from $100-$300. Again these speakers will not compare to the likes of SONOS, BUT most people are quite amazed at the clean sound that comes out them being small and no wires.
    Apr 2010
    East Texas
    9,626
    That's why I changed from a bluetooth speaker. Just couldn't get the area coverage out of ONE speaker.
    If you are looking for an inexpensive / flex route and can fully shield from the weather, an Airport Express will let you run AirTunes to any stereo or amplified speakers.
    Kayak Pool - 12 ft. x 24 ft. rectangular, 5˝ ft. deep end
    Frog System, Sta-Rite-Modular Media Cartridge Filter, Pentair 1 H.P. pump
    AquaPRO Pro500 heat pump & Automatic AutoGuard™ Pool safety cover
  20. Back To Top    #20
    Kinglangon63's Avatar
    May 2014
    Ontario,Canada
    41
    I installed 2 kills h speakers with a Onkyo wi fi receiver and it works great. You can play music from your iPhone/iPad/ spotify and all that good stuff
