Results 1 to 13 of 13
Thread: Keeping pH & TA at proper balance with newer plaster
    Jun 2015
    Glendale, AZ
    156
    This is newer plaster/pebble March 2015...I have been trying to keep my pH around 7.4 - 7.5 with TA around 95 - 100.....with that I have to add about 15 oz of acid a day and then every 3rd day or so bump up the TA with baking soda.
    I had been keeping pH around 7.8, with TA around 85 - 90 but still added about 15 oz of acid daily, either way still using about the same amount daily.
    Will the pH rise slow down as the plaster ages more or am I balancing the water wrong?
    I understand the issue with pH reading with high chlorine and I have actually verified my numbers with the use of 2 commercial pH meters. I have also found that using the Taylor reagents, I can get reasonably accurate pH readings up to about 15 ppm FC readings. I should add, I now let the FC drift lower to about 9-10 for a very short time and check pH to again to get correct numbers.
    Today's numbers:
    FC 14.5
    CC 0.0
    pH 7.6
    TA 95
    CH 350
    CYA 150 (I know, will handle this later)(long story here)
    Thanks for any recommendations....
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Jun 2014
    15,023
    Re: Keeping pH & TA at proper balance with newer plaster
    Have you seen this page: Pool School - Start-up New Plaster. It references a 6-12 month transition period.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I would stop raising your TA. It is fine for TA to drop to 80 at least and lower is probably OK too. As TA gets lower PH will rise slower.
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by Texas Splash View Post
    Yes, I did read that numerous times, I think if it had been done correctly, I may have had fewer issues. The Pool Remodel Company (3rd generation in business for over 50 years) had there own way of doing it and with the help of the pool store, I ended up with a CYA I have now.
    I no longer find it a surprise that people in business are not educated/knowledgeable, don't care to learn and the worse thing is they think they are right.
    Quote Originally Posted by pooldv View Post
    I think I may do that....let the TA drop to around 80. Where should I let the pH get to before adding acid?....usually I add when it gets to around 7.7 or 7.8
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by oldguy70 View Post
    Especially with new plaster, I wouldn't let it sit at 8+ for long...by 7.8-7.9 you should be doing some figuring.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    JoyfulNoise's Avatar
    May 2015
    13,177
    Keeping pH &amp; TA at proper balance with newer plaster
    Why have you set a pH target so low (7.4-7.5)?
    If I were in your shoes, I would lower the TA to 80ppm and just try to stay in the 7.6-7.8 pH range. Your CSI will always be less than zero. You will also add less acid.
    Just for clarification, if you use a TA of 80ppm and assume a mild amount of salt in your water (500ppm) with a water temp of 88F, then your CSI would be as follows -
    @pH = 7.6 -> CSI = -0.19
    @pH = 8.0 -> CSI = +0.13
    Those values indicate balanced water. Your CSI is 0 at a pH of roughly 7.8.
    Matt
    Mar 2015
    Harvey, LA
    300
    Re: Keeping pH &amp; TA at proper balance with newer plaster
    I don't know about OP, but for me, if I target 7.6-7.8 with my fairly new plaster, I will be over 8 by next morning's readings.
    May 2015
    13,177
    Quote Originally Posted by gilbee View Post
    We should discuss this in a separate thread but I see from your test log (nice job on that!) that your CYA is at 50ppm. That is too low for an SWG pool. If you are running your SWG a lot to compensate for the low CYA, then the excess aeration caused by the SWG could be causing your excessive pH rise.
    Matt
    Jun 2015
    Glendale, AZ
    156
    Ya, that is why I was trying for 7.4 - 7.5, when I was up around the 7.8 - 7.9 I would be at 8+ by the next day.
    I have been trying to get a handle on how much the pH rises in a day, seems to be maybe around .3 - .4
    May 2015
    13,177
    The reason why I mentioned raising your pH target is because by going lower than 7.6 you are forcing your CSI to be negative which is counterproductive while plaster is curing. The detailed chemical explanation is covered here.
    In short, you'll get off the crazy-train cycle of pH rising quicker if you keep your CSI more positive while the plaster is curing. If you target your TA and pH a little better (try for 0 or slightly positive CSI), you may be able to stretch out the time between acid additions. This is also why TFP recommends a bicarbonate plaster startup process as opposed to the hot-start process that so many in the plastering industry use. Unfortunately, you're at the mercy of the plastering company on that front.
    Matt
    Mar 2015
    Harvey, LA
    300
    Yeah, I suppose we can, but mine wasn't intentionally 50...I didn't realize I was judging my cya inadequately high until today when I received a batch of 50ppm solution from tftestkits to see what 50 really looks like...rest assured, I'll be raising mine very soon.
    Jun 2015
    Glendale, AZ
    156
    My problem is the high CYA, once I get that taken care of, I will able to use a lower TA and maybe a better pH number and try for a 0 or slightly positive CSI......on the subject of CSI, I was told to 'Keep your parameters within the guidelines suggested here on TFP and ignore CSI.'
    With that in mind, I am probably ok with where I am now and get my CYA down, then see what I can do. I will try TA down around 80 and see if the pH will be a bit more stable.
    May 2015
    13,177
    If you have normal pool water and you follow the TFP Recommended Ranges for your pool type, then you don't have to worry about CSI since your water will be balanced by default. The recommended ranges are designed, in part, to produce a balanced CSI.
    Your situation, however, is not normal. First, your CYA is way too high and requires at least a 50% water drain to bring you down to a manageable level. Second, you had a newly replastered pool surface. Therefore your ranges would be different during the curing process (higher TA and pH targets). Unfortunately your plastering company and pool store did you no favors and now you're left to clean up the mess.
    Matt
