Thread: Heating via the sun
    Jul 2015
    OHIO
    1
    Heating via the sun
    I have found that the water will heat quicker by removing the solar cover during sunlight hours and trapping the heat in by replacing it in the evening. The question I have is will it heat "quicker" with the pump on high or low, or not even on?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Heating via the sun
    Welcome to TFP! I find that'd the water can circulate it heats more evenly.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mar 2007
    San Rafael, CA USA
    12,082
    Generally speaking, you get faster heating removing a cover during the day IF you don't have dry air with a lot of evaporation. Otherwise, the heat gain from the sun is cancelled out by the heat loss from evaporation. Using a mostly clear solar cover (or a light blue cover that effectively lets most light and especially infrared through) is even better since it eliminates evaporation but lets most light through to heat the pool. What color and opacity is your cover?
    Circulation is better because it distributes the hot water throughout the pool. Otherwise the surface will get warmer and will thermally conduct heat faster back to the air.
    May 2015
    Quebec, QC
    37
    Solar covers also reduce evaporative cooling, which depends on wind speed at the water surface. On a windless day, and in direct sunlight, the water heating rate will be similar with/without the cover, but increase the wind speed, and you are better off keeping the cover on to reduce heat loss through evaporation.
    14 x 28 Jacuzzi vinyl inground pool, Jacuzzi Laser 250 sand filter, Hayward 1 HP pump.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Quote Originally Posted by Willfire67 View Post
    Just curious as to what kind of cover you have (e.g. semi transparent blue bubble)?
    Mark
