Results 1 to 12 of 12
Thread: Pump maintenance
    Mar 2015
    Mount Pleasant, TN
    59
    Pump maintenance
    Hey everyone,
    So my pump motor decided to give up mild season. Not sure yet if it's the capacitor or rust. I just shut it off to setup the vacuum and it hums when I turned it back on.
    Here's the pump:
    Anyways, I'm working on plugging my drains using these new plugs:
    Low and behold it fits great for the basket but not for the return jet. Here's the return setup:
    I believe there's an insert fitting in there but not sure and I can't get it lose if there is one.
    I did find something and have NO idea what it is...lol.
    Any ideas?
    Pool Stats: 24" Round Above Ground - Vinyl - 13,500 Gallons | Filter: Hayward Sand S180T | Pump: Hayward Power-Flo Matrix | Testing Kit: TF-100 | Mount Pleasant, Tennessee
    Mar 2015
    Mount Pleasant, TN
    59
    Re: Pump maintenance
    Well I'm going to be waiting til later to go out there and work on it. Just got stung by a wasp. Did you know that they really hurt!
    Don't have an answer for you unfortunately but the same thing happened to me last summer with our pump, replacing the capacitor did not fix the problem. Loved having to buy a new pump 3 days before going on vacation
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    Quote Originally Posted by eric.mathison View Post
    The threaded part of your return jet comes out. There should be slots inside it for a key to fit in to unscrew it, then i believe your plug will screw right in.
    like this one
    G
    Jun 2015
    Wildomar, California
    423
    If your fitting still doesn't come apart you can always stick a cork, or carrot, or ?? and disconnect the hose from the filter and secure it over the wall of the pool into the water. Not for a long time, and kind of funky but if you haven't got another choice it will work. This would be a last ditch solution to get your pump fixed
    Mar 2015
    Mount Pleasant, TN
    59
    Well I ended up putting a zip lock bag over the hole and screwed the eye back in. There is quite some suction but it worked! Hopefully I won't need to go fishing for it lol.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    I know how you feel about the wasp sting. I got one on the nose a few weeks back and boy did it hurt! I may have uttered spurious comments about the parentage of the wasp!
    As for the pump, the capacitor is the usual culprit, but I don't believe this model has one. It may have a centrifugal switch instead. Pull off the back cover and see if there is a capacitor behind it. If not, this thread may help you troubleshoot the problem. motor repair advise needed Hayward powerflo sp1580Z2 1.5hp
    Love TFP? Become a
    TFP Supporter!
    Mar 2015
    Mount Pleasant, TN
    59
    Cool I'll check it out. Thanks
    Mar 2015
    Mount Pleasant, TN
    59
    So I took off the back and front parts.
    Here is a pic behind the back cover:
    There's not much there. Looks like I need to go a bit further in. The good news though, the motor spindle moves freely and easily using a flat head.
    Any suggestions on what to do next?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    To find out if it's the capacitor you might need some help to turn the motor on and when it's humming try to spin the shaft (that's the if you can do it safely part). If it starts up then it is the start capacitor that's bad.
    That chunk of threaded plastic in the wall is part of the "eyeball". The more you tighten the part in your hand to that other part the harder it is to adjust the eyeball.
    Solar Blanket, Well Water, Borax Added. 68
    Mar 2015
    Mount Pleasant, TN
    59
    Well there's no capacitor, only a centrifugal switch. I was able to put some lithium grease on the springs to help loosen it. Now it hums for 10 secs then starts up. Woohoo.
    However I think I'm on borrowed time and the motor will need to be replaced the next time I turn it off. I guess for the rest of this season, I'll have to eat the electric bill and leave it on 24/7.
    This model doesn't look like you can access it. The switch is inside the motor casing and there doesn't look to be away to access the inside of the motor.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Have no idea what this is.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
