Thread: 12.5% Chlorniating Liquid - Columbia, SC
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    A couple of you from the area have asked, and well, I finally found it - 12.5% chlorinating liquid in Columbia, SC (Forest Acres actually).
    Jack Oliver Pool, Spa & Patio stocks 1 gallon jugs, $4.50 each. As of today, date code was 15-121 and being stored inside the store in the middle of the sales floor. Nice and cool, no direct sun. The company is run by two brothers, Jack builds pools and Stephen runs the store. Two former Florida guys who know how a pool should be run with liquid chlorine. For full disclosure I purchased my M5 and my Hot Springs hot tub from them. I don't know how,I missed the chlorine before.
    Talking to Stephen, he said they would,like to have a bulk chlorine tank but are afraid that sales would not make it worth their while.
    The price works,out to use about the same as WalMart 8.25% but you don't have to deal with Walmart.
    Jack Oliver Pools - Home
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: 12.5% Chlorniating Liquid - Columbia, SC
    And you get to haul like 40% less bottles. Or is my math whacky? I'm sitting in the pool with a beverage and no calculator so I could be way off on that.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by pooldv View Post
    The 12.5% chlorinating liquid is in Trade % so is % Available Chlorine by volume and has a Weight % Available Chlorine of 10.8%. The 8.25% bleach is the weight % of sodium hypochlorite and has a Weight % Available Chlorine of 7.9%. So from a weight perspective, it's 7.9/10.8 = 0.73 so around 27% less weight to carry for the equivalent chlorine amount.
    In terms of volume, the 12.5% chlorinating liquid is 12.5% Available Chlorine by volume while the 8.25% bleach is 8.64% so it's 8.64/12.5 = 0.69 so 31% less volume to carry. The extra savings in volume comes from the fact that the chlorinating liquid is a little denser than the bleach.
    May 2014
    Franklin, NC
    9,184
    Well, it's a little outside my normal driving area, but very close to Trader Joes where I get my wine so I'm keeping it as an option. Ollies has 10% here for $2.99 which is a decent savings over both Walmart and the 12.5 I found. When Ollies runs out I will switch.
    I'm going through a lot this weekend doing a SLAM . That will be the subject of another post when I'm done.
    Support the site
