Thread: Power Supply water proof?
    May 2011
    MA
    18
    Ok guys, probably a stupid question but this is my first robotic cleaner, thus want to know if the power supplies are typically water proof. I ask as I put my cleaner in this morning and went to cut the grass. Well the clouds rolled in quickly and thundershower started. Was just at the end of cutting the grass so wanted to finish the lawn before it really started to downpour. Well I lost and downpour started. Forgot about the cleaner so I ran to the back to unplug the unit and put it in the shed. So I ask is this actually something I need to worry about? Didn't read anything in the manual to state whether or not the power supply is waterproof or not. What do you guys think?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Power Supply water proof?
    Most state that they are water resistant. I know many users on here have devised a "doghouse" to put their power supplies into either for storage or during use. I would recommend protecting the power supply from rain and sun whenever possible for the peace of mind. A plastic bin, such as Rubbermaid that is large enough to cover the power supply when the bin is inverted is sufficient. You can add slots for the cords to pass through if needed. I have a table that is very close to the pool in my case so I put the power supply on a chair and slide the chair under the table when running my robot. When not in use, the power supply goes in a deck box like this one:
    Isolated Spa - 345 Gallons
    Jun 2015
    Southeastern PA
    20
    If you are out of warranty, you might consider waterproofing your unit. As stated before, most are considered water resistant. I have a dolphin and the on/off switch is in a rubber enclosure but that is only protection from rain or splashing. I removed the cover (6 screws underneath or so) and created a silicone 'gasket' around the base where the cover meets the heat sync. I wouldn't drop it in the pool but I'm confident that it will be protected from a driving downpour at this point.
    May 2011
    MA
    18
    Thanks guys this is exactly what i wanted to confirm. I will take your recommendations and ensure that I have some protection, particulary if I plan to leave it unattend for a while.
    Thanks again.
    Jul 2011
    Broken Arrow, OK (Tulsa)
    295
    I use a small vertical smoker grill cover for my Dolphin DX4. I keep the power supply on the Dolphin's caddy, and the cover fits it pretty well, keeping the rain off the power supply. (Have had 3 power supplies for this cleaner fail, but none since I started using the cover).
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
