Ta Dah, pool is up, pump filter running, new skimmer-return installed, no leaks, solar cover in use, did wall and floor brushing.
Last week I didn't have the filter and pump running due to needed a new skimmer and gasket. All I could do was test and use sump pump to recirculate chemicals, I tested 2 x a day. One error adding washing soda and white cloud. I did a back wash and rinse of the filter.
I ran pump on high about 3 hours but didn't want to leave on all night till I make sure it's a well behaved pump.
So now I have things better can you make some suggestions?
todays results
6.5 FC ( last night was a 2 FC so added 34 oz bleach)
0 CC
7.8 pH
150 TA
35 CYA ( added CYA last Monday)
550 CH ( yes our water is very high calcium)
Temp 75 degrees
This past week I have added Muriatic acid and had he pump areating to help the cloudiness. It's better but still cloudy white.
Pump was on high a bit this am and now I have it on low.
So how do these numbers look?
todays results
0 CC
7.8 pH
150 TA
Temp 75 degrees
