Thread: Test results - anything to be concerned about?
    May 2015
    Jacksonville, Florida
    15
    Hello, I'm hoping for some feedback on my results this morning.
    pH: 7.6
    FC: 7ppm
    TA: 100
    CYA is currently 40 although I have a sock in the skimmer now.
    Calcium Hardness: dropped 31 drops using test kit and solution was still not very blue so ppm is probably 1000+. Water is clear.
    Salt Level: 3500 ppm according to Hayward Aquapod reading
    Should I be concerned about the hardness or salt levels? Hayward recommends salt range at 2700-3400.
    Thanks all.
    Re: Test results - anything to be concerned about?
    Please post some more info about the surface, dimensions, and gallonage of your pool...and which test kit are you using?
    How does your water look?
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    May 2015
    15
    Sorry thought my signature line was showing.
    Water looks clear.
    My Pool: 19,000 gallon In-Ground Screen Enclosed, Finish: NPT StoneScapes Mini Pebble Tropics Blue, Controller/Heater: Hayward ProLogic P4 w/T-15 SWG
    Pool Filter: Hayward Cartridge Star Clear Plus, Pool Pump: Hayward VSP SP3400VSP, No Spa, TF-100 Test Kit.
    Pool Installation: Plaster Complete 5/23/2015
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,392
    You need to get that CH down.
    Have you tested your fill water?
    AND HI to another Florida person! Some pool weather we are having for sure!
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    That CH number seems doubtful.
    Questions: Did you forget and possibly use the 25 ml sample size but use the 10 ml multiplier? Have you been chlorinating with Cal-hypo powdered shock? Was there anything done to the pool like a no-drain acid wash that could account for CH levels being that high? If that number is correct, the walls and floor of that pool must feel like sandpaper. Or they will soon.
    May 2015
    15
    they did a no-drain acid wash in late May when the NPT StoneScapes finish was done. The walls and floor feel fine right now. I'll retest to be sure I did it right. Thanks for the feedback.
