Thread: Reset an Aqua Rite AQL PS-4 showing High Salt / Amps
    Hi everyone!
    I have a 10 year old salt system, with an Aqua Rite AQL PS-4 / Hayward Turbo Cell-15. I recently replaced the Turbo Cell-15 but cannot get the system to accurately gauge the salt level, compared to using two test kits...
    Is there a way to reset the board? Currently when Diagnostics are run, it shows 6400 ppm, and then after the diagnostics end, the system window will show 3600 ppm, which is still high...
    I have ordered another board, but would like to know if there is a way to resolve this problem... as a result of the "perceived" high salt level, the chlorinator never kicks in...
    Thanks in advance for any thoughts or tips.
    Mike
    Atlanta, GA
    15,000 gal
    Salt system - Aqua Rite AQL-PS-4
    10 years old
    Re: Reset an Aqua Rite AQL PS-4 showing High Salt / Amps
    I suspect that the 6400 is probably correct. Get a Taylor k-1766 test kit or use a good meter.
    As the old cell began to fail, it would read the salt level as lower than actual. If you added salt according to the box until the cell failed, the salt would probably be in the 5500 to 6,500 ppm range.
    Also, make sure that the t-15 cell is selected in configuration.
    What test kits did you use and what were the readings?
    Support the site
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    If the unit is 10 years old it will not have a selection for cell type. Unless the board has been replaced and it will ask what cell is needed. Remember, the unit measures the salt level every time it reverses polarity and averages it with the present reading. Test with an independent test kit.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    All versions of the AquaLogic can select between the T-5 and the T-15.
    Support the site
