Thread: White stains on ceramic tile
    Aug 2013
    Dallas, TX
    78
    Hello,
    I've attached a picture showing some white stains that we have on our blue ceramic tile around our spa spillover. We've only owned the house for a couple of months, so we have no idea how long these stains have been there. Our water is very high in CH because the previous owner's pool service used cal-hypo once a week to shock. Since we've owned the pool, we've put nothing in the water except bleach and some muriatic acid. What's odd is that these stains appear where the water doesn't make contact with the tile. Any ideas what these stains could be from, and how to remove them without affecting our nice clear water?
    Thanks!
    23,000 gal. IG gunite pool, DE filter, elevated spa with spillover, Polaris 280 cleaner
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: White stains on ceramic tile
    It is probably calcium scaling. Pour a little muratic acid on it and see if it fizzles. If so it is calcium scale. You need to post a full set of test results so people can better help you. What test kit do you have?
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Aug 2013
    Dallas, TX
    78
    I have the TF-100. The last time I checked CH a couple of weeks ago, it was consistently reading 860. Since it was so consistent, I stopped checking it regularly in order to save reagent because nothing has been added to the pool that would have changed the reading.
    My other numbers are as follows:
    CYA 70
    FC 8
    CC 0
    TA 100
    pH 7.9 (need to add acid anyway to lower this)
    Will the muriatic acid remove the stains, or will that just indicate if it's indeed calcium?
    JoyfulNoise's Avatar
    May 2015
    13,194
    It's most likely evaporite from mist/splash created by the spillway. Evaporite is as the name sounds, water evaporates and leaves behind all the solid compounds in it. It's mostly a mixture of calcium carbonate and salt. That being said, sometimes a little diluted Muriatic acid in a spray bottle (5:1 water to MA, always wear eye protection!) will work wonders.
    If it becomes thick and adherent (you can't scrap it off with a finger nail) then you might consider a pool tile cleaning service and one that specializes in soda blasting (kieserite, aka magnesium sulfate, blasting). I had bad calcium scale all over my pool once and I needed a professional clean. The nice part about kieserite is that it is hard enough to blast away the calcium scale but soft enough not to damage the glaze on ceramic tiles. Unlike using a pumice stone, kieserite will not damage grout or tile glaze.
    Matt
    30,415
    It'll usually remove it completely. Use with caution. The process will start over so you'll have to do it from time to time but yours does not look too bad and will likely clean up nicely.
    Aug 2013
    Dallas, TX
    78
    Ok, thanks for the suggestions!
