Thread: Making a site for an easy set
    Jul 2015
    Oklahoma City, OK
    4
    My husband bought me a 12'x20' index easy set pool so I can exercise without getting overheated (stupid autoimmune disease). We have no idea what we are doing and thought we could just set it up in the backyard. After reading the manual I thought the biggest problem was keeping the Bermuda grass from growing through the liner.
    But after reading on here for a while, I think we need to level the ground somehow. The yard is pretty level overall but there are hills and valleys. Neither of us are able to work out in the heat. Just getting the pool set up was going to be our limit.
    Are we going to have to create a totally flat and level pad for this pool? If so, can anyone estimate the cost of hiring someone to do it? We are in Oklahoma City. Thanks!
    Total noob with 12'x20' intex easy set still in the box.
    Jul 2015
    Oklahoma City, OK
    4
    Re: Making a site for an easy set
    I also thought about getting 12 sheets of plywood to smooth out the ground. Is that something that would work?
    May 2015
    Colorado Springs
    94
    Hi Tiger dawn, I too have an autoimmune disease and it was really long and hard doing the work to install hard wall pool. It was easier giving birth I swear. I know the ground must must must be level, no more than 1" out of level. I thought about renting a transom/laser level from Home depot but it was $70 and I knew with my slow work it could take days. I agree hiring is a great idea if you have the money. But the installers have to be good at leveling. I hauled all my gravel and dug the clay little by little. I used a bunyip ( water level) I made for $15 or less. I was with in 1/4 to 1/2" of level, pretty good. I never did rent the laser level. I used pink polystyrene over and old carpet( it's a desert here so dry) that is on top of clay soil. I did 98% of the work. I thought hauling sand to put under pool in a wheelbarrow would be too much for me. Seems I was very wrong cause maneuvering a liner to get wrinkles out was a lot harder-liver suctioned it self to. BUT that polysturene foam ( took 1 roll of gorrila tape to tape seams for 18 ft diameter pool) feels great under the liner.
    My newbie thoughts are if you used plywood there could be splinters, good chance it will warp and make poke up in odd places. Maybe polysytene foam would work better on an easy up?
    The doctor mentioned chlorine was not good for autoimune thyroid problem and consider a UV light to help sanitize. I haven't figured that out yet.
    Used pool 1995 Lomart 18'x48" just installed 7/16/2015, Hayward Power Flo Matrix 1 HP 2 speed pump, 16" Rx Clear Radiant sand filter ( used pea gravel and zeolite) foam wall, polystyrene bottom, liner 25 gauge overlap, TF-100 test kit. Son training for 2018 Paralympics, Hoping for solar heater of some sort. Good chance Labrador will be in pool. Colorado Prairie, 6000 ft elevation high mountain desert, clay soil
    Jul 2015
    Oklahoma City, OK
    4
    We've decided to send the pool back and try a gym with a pool. We plan to move next year so maybe we can make a pad at the new house.
    May 2015
    Colorado Springs
    94
    I just ruined a pump by using an extension cord. There are so many things to think about and care for on a continuing basis. The used pool was $150 but it's gonna cost $2000 to get it up an running. That $2000 would pay for a great pool membership.
    Jul 2015
    Oklahoma City, OK
    4
    We found a great gym with a nice pool and lots of weights and machines. It is clean and well maintained. I think it will work until we can afford a home setup.
