Thread: what size SWG for a 25,000 gal pool?
    Oct 2014
    DFW Texas
    80
    I'm thinking of upgrading/converting to salt... I was wondering if I should get the 40 or the 60? In other words, is it good to go way oversize for better chlorine generation?
    7-10 year old In ground 20,000 gal, Aquabright ecofinish W/ Spa, Propane heater, waterfall and infinity jet, 60 sq foot DE filter, Intellitouch+Intelliflow pump, IC40 cell, Racer cleaner
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: what size SWG for a 25,000 gal pool?
    Hi,
    yes it is better to go bigger. A bigger SWG will mean you can run it at a lower output. And that means a longer lifespan for the cell.
    The 60 would be preferable. The 40 would be suffient but wouldnt last as long.
    Divin Dave,
    Jun 2014
    Portage, MI
    12
    The general rule is to order a cell that is rated at twice your pool size. However, like me you are between sizes. I have a 22k Gallon pool and have the T-15. It has been able to adequately chlorinate our pool at 50% running 10 hours a day. I am a lot farther north than you, so I would wait to hear from someone closer to your location with a similar size pool (and I'm sure they will be here shortly!).
    22k gal, IG plaster pool, 1/2 hp Sta-Rite Max-E-Pro pump (P6E6C-204L), Sand Dollar Cristal-Flo 300# sand filter (CFII24), RayPak NG heater (P-R266A-MN-C), AquaRite T-15 SWG, Intermatic Hydro-King (T104P201), Aquabot Xtreme, Taylor K-2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Right now I am running my IC40 at 60% about 8 hours per day, 20k gallons. We swim every day and a lot on the weekend. Year 3, season 4. I am very happy with it.
