Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Bulk borax
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Bulk borax
    I'm interested in adding borates to my customers pools. My dealers aren't stocking any proteam stuff plus it's pricey. Anyways I have 40 customers that I'd like to start adding to and I don't wanna raid every Walmart for 50 miles. So I'm asking to see if any knows where I can buy bulk "borax" so I can save my customers some money. Naturally I can get all the acid I need as my dealers stock plenty of that. Any information would be great!
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Bulk borax
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: Bulk borax
    Why not use boric acid? You can buy it from Duda Energy in 55lb pails. They may even supply larger bulk quantities.
    I'm not sure how it works out in all regions but for me using boric acid was cheaper than borax/Muriatic acid process ($56 total for boric acid versus $67 for equivalent borax/MA process).
    Matt
    May 2015
    13,247
    Re: Bulk borax
    These guys sell borax in 2000lbs bulk form It's a steal at $0.48/lb...You might need your own dump truck and a tanker full of muriatic acid though
    Matt
    May 2015
    13,247
    Re: Bulk borax
    Quote Originally Posted by X-PertPool View Post
    Just so you know, in my pool with it's high CH, adding boric acid was a much easier process. I needed 40lbs and I added it by broadcast around the pool in 2 lbs increments and brushed every 10 lbs. It took me less than 30mins to get the boric acid in the water and fully dissolved. If you do the borax/MA process, you're going to have to do it in batches and do pH testing in between additions to make sure you're not spiking the pH. I bet doing it by borax/MA will take you twice as long.
    Also, make sure you get granular form and not fine powder. The fine powdered form of boric acid is really meant for insecticide use and it will float on the water surface and blow all over. Granular just sinks right in.
    Matt
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Bulk borax
    Is there any disadvantages to boric acid over borax?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Bulk borax
    No disadvantages. Technically the borax and acid result in boric acid but also increase sodium chloride salt levels. Adding boric acid just adds boric acid with no extra resulting salt.
    May 2015
    13,247
    Re: Bulk borax
    I'm not sure what others think, but the choice of method may also depend on other water parameters. As I stated previously, for my pool which has high CH and a pH that always drifts up, boric acid made more sense as it precluded any possibility of causing calcium carbonate precipitation. If your pool customers have low CH and pools that tend to drop in pH, then borax may be a more desirable approach than boric acid.
    Since this is a service you are providing to your customer base, I'd assume you'd want the fastest and cheapest method possible. In which case, the boric acid route would seem to be the way to go as long as you properly prep the pool water first. Remember that you need to lower the TA before you add borates. Otherwise, it is much more difficult to do after the fact.
    Matt
    Re: Bulk borax
    The rate at which TA can be lowered is dependent on the rate of carbon dioxide offgassing which does not change with borates. Therefore, the amount of acid that can be added per unit of time should be the same.
    If anything, lowering TA would be easier after borates because you could add the same amount of acid on the same frequency as without borates or you could add more acid at longer intervals, which could be better for someone doing it as a service where they can't be there every day.
    Support the site
    May 2015
    13,247
    Re: Bulk borax
    Quote Originally Posted by JamesW View Post
    That doesn't sound quite right to me but perhaps this conversation is headed for "The Deep End"
    The addition of acid is what consumes carbonate alkalinity by converting carbonates to bicarbonates. The bicarbonate is then driven to the formation of aqueous CO2 in equilibrium with carbonic acid. So, when aeration occurs, CO2 is driven from solution and the reaction equilibrium shifts demanding the formation of more carbonic acid from bicarbonate and hydrogen. In all those reaction steps, hydrogen ions are consumed and therefore the pH ultimately rises.
    CO2 out gassing rates are, in part, pH dependent. Therefore if it requires more acid to lower the pH with the presence of additional solution buffering due to the borates, then that is what I mean by being "harder" to lower TA as it takes more acid to get to a lower pH. Perhaps instead of saying TA I should have specified "carbonate alkalinity" as borates do add to the total alkalinity of the solution (less so than carbonates but still noticeable at 50ppm).
    Matt
    Re: Bulk borax
    Going to start a separate thread.
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Bulk borax
    If one needs to raise the pH, one can use Borax for that which will raise the TA about half as much as using pH Up (sodium carbonate), but one could instead aerate the water which raises the pH with no change in TA though that may take longer. However, I wouldn't mix up the need to raise the pH with the process of lowering the TA. If your point was that one already had 20 Mule Team Borax on hand for the purposes of raising pH generally, then yes one could use that and acid if one wanted to, but personally I find boric acid so much easier and foolproof that I prefer it. It avoids the pH swings during the acid and Borax additions and it doesn't result in extra salt.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Bulk borax
    If I have a 20k gallon pool and I add about 50 lbs of boric acid to bring it up to around 50ppm. Assuming the pool was fairly balanced beforehand are there any levels I should specifically watch out for so they don't go out of wack?
    Quote Originally Posted by chem geek View Post
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Richard320's Avatar
    Jan 2010
    19,051
    Re: Bulk borax
    Poolmath says 800 oz of boric acid in a 20,000 gallon pool will raise Borate by 52 and lower pH by .3
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Bulk borax
    Okay so only a slight decrease in pH not that bad, thanks. Sorry for all the questions. Never messed with borates before but in want to keep my pools in tip top shape. I'm always hesitant when adding large volumes of chemicals
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Bulk borax
    So the price I got quoted was 1,160 + $413 for freight shipping. Which comes out to about 1.06 per pound of boric acid. How does this price compare to using off the shelf borax and acid?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    May 2015
    13,247
    Re: Bulk borax
    Cheaper I think. Walmart sells a 4lb box for about $5 or so depending on sales and acid, retail and cheapest I can get is $4.75/gal
    So using boric acid at $1.06/lb is a great price-point. Now tell us, how much ya gonna charge your customers
    Matt
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Bulk borax
    That's a good question. For a point of reference I charge 2$/pound for "alkalinity increaser" But most of my pools will be taking about 50 pounds so I think I may offer a bulk discount rate and then have a higher rate for supplementary additions in the future. I'm not happy with the 400 dollar freight charge and I tried calling around local companies but had no luck finding a local source. None of my pool companies carry it, metal plating, janitorial, chemical supply. no luck local
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    38,475
    Re: Bulk borax
    Who did you get the quote from? Duda also sells on eBay with free shipping ... Of course they raise the price to compensate
  20. Back To Top    #20
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Bulk borax
    So if you are looking at 1500 pounds of boric acid, then this would be 27.2 55.12-pound containers from Duda Diesel so say you get 20+ for the price break of $42.95 each so that would be $0.78 per pound of boric acid, but without shipping costs. So you should contact Duda Diesel to find out those shipping costs by using this form.
