Thread: Shock n Swim ?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Shock n Swim ?
    If I ever need to shock my pool again... anything wrong with Shock n Swim? At $2.60 per pound (which is supposed to raise my pool 4ppm), it's cheaper than equivalent bleach (1 gallon of 8% should do the same). I would only use it if I needed to raise FC for shocking. I assume it has a much longer shelf life than liquid.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Shock n Swim ?
    It does have a longer shelf life but it's cal-hypo. Every pound will raise your FC by 3.8 and your CH by 2.7. Prolonged usage depends on your CH level.
    Isolated Spa - 345 Gallons
