Page 1 of 4 1234 LastLast
Results 1 to 20 of 73
Thread: Help! Finally realized that the pool store is crazy....
    Jul 2015
    Pittsburgh
    38
    We always used to just use bleach/baking soda/rock salt with our Taylor K-2005 kit to balance things out until we had a big problem with clearing it during the spring of 2014. I went to the Pool Store, bought hundreds of $$ in chems and got it clear... for a bit. We had algae problems off and on all summer and trouble keeping readable chlorine levels. Fast forward to this year. Bought $300 worth of chems right off the bat so we could open up early. We had a tree fall on the pool, a short in the wiring to the pump causing 2 weeks of no circulation, and a leak in the lines somewhere shortly afterwards. Fixed the leak with some amazing gel that we poured into the skimmer.
    After re-reading my "pool bible" (aka Taylor kit instruction book) I realized how much I was overspending on chlorine by getting tri-chlor, so I've reverted to good ole bleach. Our pool is finally blue after a big algae bloom, but still a little hazy. It's been raining almost everyday for around a month. Couldn't get any chlorine to register on my kit. Thought maybe my testing bottles were too old. I took a sample to that pool store since they do free testing, knowing I wouldn't buy anything from them, but wanted to see if my tests were true. Here are the results:
    TC: 0
    FC: 0
    pH: 7.4
    TA: 65
    CH: 175
    CYA: 110
    They told me I have something creating a high chlorine demand and need to burn out the pool with a 74% shock they sell. I politely walked out. What really gets me, is that on their analysis, they say that CYA range should be 30-150. No wonder I can't get the FC to register!
    After reading Pool School and some other threads, I'm wondering - do I need to SLAM the pool, or do I just need to drain and fill a few times to get the CYA down? What could be causing the haze? Early sign of algae? I killed the last bloom by dissolving 10lbs of the Sam's club granular chlorine and pouring it in. That was just a few days ago. We've "shocked" SO much, no wonder the CYA is through the roof.
    We have a pool party scheduled in a week - is there hope for the party? Give me some advice! I'll be ordering the more accurate FAS/DPD test soon.
    50 yr old in-ground plaster pool
    15'x40' 3ft to 9ft
    22000 gallons - we think
    1hp jacuzzi pump and sherlock cartridge filter
    Taylor K-2005 test kit
    Jun 2014
    15,027
    Re: Help! Finally realized that the pool store is crazy....
    Sorry you had to take the long, painful road to finally see the light. But we're glad you are here. So first things first .... CYA! Yuck. Yep, the only way to reduce adequately is a partial drain. You want that CYA lower before you SLAM or add any more chemicals. Since you have a plaster IG pool, you need to be careful of draining too much if you have a water table that could "float" or disrupt your pool shell. Having said that, a healthy drain is usually more efficient that many very small drains, but I'd recommend about a 40-50% drain and exchange of water if you are able to do so. See how that reduces your CYA. However you slice it, remove/exchange some water to get you to a decent CYA. Even if you only make it to 50 or 60, that's at least manageable. You'll use a little more bleach for a SLAM, but after that not so much.
    SO hey, welcome to TFP! Let us know if you have any more questions.
    PS - Definitely get that FAS-DPD kit ordered ASAP. You will need it to measure FC and CC during your SLAM.
    My advice would be to read the articles in POOL SCHOOL two or three times and to utilize the pool calculator http://www.troublefreepool.com/calc.html.
    You may be able to get it clear in a week, but you have to be willing to test and keep the chlorine levels at SLAM levels and purchase as much bleach as needed to keep them there, which will be a lot due to the high CYA. You would be better off doing a 1/2 drain and refill, but I am not experienced with plaster pools and the drain and refill process with those...and the pool store was correct in saying that you needed to raise your chlorine level due to demand, but do it with bleach due to the high CYA...
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,459
    Welcome to TFP!
    Yes, there is hope. Drain 30-40% probably twice. Or if you are comfortable with draining about 60% to get your CYA down to 40-50.
    Get one of the Recommended Test Kits, I use the TF100 from TFTestkits.net. Or order the FAS/DPD seperately from tftestkits if the rest of your kit is pretty full.
    When you get it give us some test results and get ready to SLAM Your Pool.
    Here are some of my fave Pool School articles to read while you watch your pool drain. .
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Jul 2015
    Pittsburgh
    38
    Thank you - you all are awesome! I'll start draining tonight. I already ordered the FAS/DPD on its own, because I keep my kit well stocked. Won't be a problem to drain half of it in one go - and then maybe we can finally get the two large stones at the bottom of the deep end that landed there when the tree fell. I'll refill, check the CYA, and then report back. And I'll keep reading the articles on here. I'm such a geek for this stuff - I love understanding how it all works!
    15'x40' 3ft to 9ft
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,428
    LexieLou! I had a kitty with that name! She was such a special kitty!
    You are so going to love your pool the TFP way and LOVE the money you will save!
    Just read and following the directions to the T and you will have a clear pool that will look like a jewel!
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi LexiLou,
    Welcome to TFP!
    If you are geeky and like learning how this pool stuff works, well you certainly came to the right place!
    Get your CYA down and SLAM and SLAM hard as soon as you get it filled back up. Its hazy now because you have the beginning of another algae bloom, which is a result of your FC not being high enough to overcome the buffering effects of teh CYA.
    Divin Dave,
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Well, every one seem to have you covered with a partial drain then SLAM, so I'll just say Welcome to TFP!
    Support the site
    Apr 2015
    Quinlan, tx
    811
    Good luck! Welcome to the pool Chemistry nerd club! . I love learning it too!
    Lisa P.
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    Jul 2015
    Pittsburgh
    38
    Thank you guys!!! So glad I found you. The support is great, especially b/c my husband is a bit doubtful that draining is the only way. But he knows I've done the research and he's trusting me. So here we go!
    Lexie
    15'x40' 3ft to 9ft
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Welcome, you've definitely found the right place to get your pool straightened out.
    You're CYA is probably high and you probably need to drain and refill as advised above. However you're trusting your CYA reading to the same people that say it needs to be between 30 and 150 and want to sell you hundreds of dollars worth of chemicals. I'd want a proper test kit and to be sure what the CYA level actually is before I drained and refilled half of a 22,000 gallon pool.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Apr 2015
    Quinlan, tx
    811
    Quote Originally Posted by robdac View Post
    Agreed! Wait for your own test kit to be safe!
    Lisa P.
    I missed the part about the results being from a pool store...wait until you get your kit.
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    Jul 2015
    Pittsburgh
    38
    I had tested everything except the CYA before I went in, and all of their results were spot on with mine. They've always matched my own. I don't doubt their readings (much) just their interpretations of acceptable ranges and responses to problems. Pool's already down about a foot... so I'm pretty committed now, lol! If it ends up being too low, I have 7 lbs of stabilizer they sold me this spring in the shed. The water bill will just be a bummer.
    15'x40' 3ft to 9ft
    Jul 2015
    Pittsburgh
    38
    Ok... you guys were making me super nervous, lol, so I just went and checked the CYA of the pool water. If the store was off, it was on the low end. I got a super high reading. Eek!
    Because half of the pool floor gradually goes from 3-9ft, it's hard to judge what's "half". We've drained about a foot and a half so far. Would two feet be good? Should I go 2 and a half? I'd rather not overshoot it, since the cost of the sewage is formidable. But I'd also rather not fill and drain a few times, you know?
    15'x40' 3ft to 9ft
    Jul 2012
    Tallahassee, FL
    30,428
    Do NOT let it get below 1 foot in the shallow end! You do NOT want to chance floating the pool!
    Kim
    Jan 2014
    Buckeye AZ
    807
    if it's over 100, you need to dilute the pool water 50:50 with tap water before doing the CYA test, then multiply the result by 2.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jul 2015
    Pittsburgh
    38
    Thanks guys - I'll keep it to two feet down, tops. I don't have any more reagent to do another test, so I"ll have to wait to test it again once it's filled and my kit arrives.
    15'x40' 3ft to 9ft
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    If you tell the water people that you were filling your pool, they usually give you a break on the sewage charge.
  20. Back To Top    #20
    DFW, TX
    24,459
    One thing is for sure, it will be better than it was yesterday! Forward march!
